Question about Craftsman Garden
25hp vertical shaft motor on a gravely 260z zero turn mower. It leaks oil from the top and bottom of the motor witless than 300 hours on it. What to do?
  • Rich Kekic Oct 18, 2013
    Would Kawasaki replace the motor because of low hours and faulty motor?i know I'm reaching, tellmesomething good !lOL
    Add a Comme
    Novelist:
  • 212 Answers
Hi Rich,
I would personally take it back to store I purchased it from. Even if its out of warranty if the store is reputable, they should help you out. If not your looking at new seals/gaskets.
Posted on Oct 19, 2013
Testimonial: "Thank you sir, take care"
2 Suggested Answers
jdlipscomb41
  • 157 Answers
SOURCE: I have a Grasshopper zero turn mower that uses
yes just reguler hydralic oil it wont hurt a thing. but dont use atf its for transmissions in vehicles
Posted on Oct 26, 2009
Mower will not drive to the right I changed the o-rings and filters on both drive motors and re-filled unit with oil but now unit will only drive with left hand no right hand action.
Sou.d like the hydrostatic transmission completly failed upon right hand drive the main gear is not engaging right drive
A knew transmission unit should fix the problem but part is pricey
Jun 20, 2016 | Toro Titan ZX5450 (54") 25HP Zero Turning...
Why does oil leak from the fuel pump and the oil filler tube?
could be a top seal leak throughing oil around and leaking down sides of motor check that number one
Aug 20, 2014 | Husqvarna RZ4216 42" 16HP Zero Turn Mower...
Gravely only clicks wont start but hour meter works
Sounds like a low battery, enough juice for the hour meter but not for the starter
Aug 14, 2014 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
My toro 6.5 hp leaks oil at the bottom of the engine runs ok
If this is the vertical shaft motor, there is a seal at the bottom where the crank shaft exits the case. On the vertical motors I've taken apart, the bottom of the case is like an oil pan. It is possible that you could have a crack in the case. But also check the oil drain plug to be tight, but not too tight. This could also cause a crack in the motor case.
Aug 14, 2014 | Toro Garden
How do i change the oil?
Read the owners manual. Drain plug should be locate near the bottom of the engine on one side. Refill through the filler tube on top
Jul 08, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
How much expect to pay for new engine 2005 zero turn snapper 22 hp commercial mower ( 52
so of the replacement engines go for $1500 depending on the shaft size at least for my scag it was so i bought a craftsman rider and swapped over the crank shaft got that for $150 seals where $20 the engine series from 18hp to 25hp look to be the same internal parts and hp changes by the carb im in ct if i can help
Jul 07, 2012 | Garden
How to change the clutch on a gravely ZTR 260z. What keeps the clutch from spinning around on the engine shaft? A diagram of the clutch assembly would help. Instruction on removing and reinstalling might...
There is an "anchor" that bolts to the chassis, and it has a rod-like part that sticks up to engage a notch in the PTO clutch to keep it from spinning. Look here -- there are parts diagrams for your mower (find the right model number) that will help a lot. Good luck!
Jul 07, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Garden Logo
85 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
