Jastek jasCS1 does not have dms function - Office Equipment & Supplies
How to use a dms in a casio 9750-GPLUS
In Run screen press OPTN key. Press F6/Next until you locate the ANGL tab. Here what it will reveal. To enter the values in DMS, use the F4 key.
Aug 28, 2014 | Casio Office Equipment & Supplies
How do i do dms and dd on canon f-170 calculator?
I could not find the manual for the F-170. Could it be the F710?.
For the F-710 the key + doubles as a DMS-DD key. see screen capture.
Mar 24, 2014 | Canon F-710 Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
Jastek operator instructions model jas1calculator
Hi Graham unfortunately I have come up blank on an official Manual for this calculator however after looking at photos of the calculator on Google, I am almost certain that the calculator is made by casio and re-branded by Jasco as a Jastek.
I think this because it looks identical to the calculator I used in school.
Photo - http://images.lasoomedia1.com.au/imageicon/pps/prod/j00518194/c_001/page_010/jastek_cs1_scientific_calculator_00456000.jpg
Here is the instructional manual for that Calculator, really hope this helps it is the best I can do I am afraid. CASIO MODEL FX300MS
http://support.casio.com/pdf/004/GY300_Dtype_E.pdf
Feb 06, 2012 | Office Equipment & Supplies
When I hit dms function the answer comes out wrong the degree minutes = the degree and the seconds = the minutes how do I change it TI-84 Silver
At first, you have to use DEGREE mode and after that you can convert your angles into DMS mode. See captured image below
Oct 05, 2011 | Texas Instruments TI-84 Plus Calculator
How do i calculate cos 30°24'
You must first set angle unit to degree.
Press the [MODE] key a certain number of times until you get to a screen that displays Deg Rad Grad. Press number key 1 to select degree.
Once this is done you can calculate trigonometric functions. To enter angles in DMS you have a key marked with degree symbol, a quotation mark, and a double quotation mark. In what follows that key is represented as DMS.
To calculate cos(30 deg 24')
[COS] 30 [DMS] 24[DMS] [=]
If you get an error message you will have to enter the seconds even if the value is 0
[COS] 30 [DMS] 24[DMS] 0 [DMS] [=]
Sep 11, 2010 | Casio FX-300MS Calculator
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
On this family of calculators, you do as follows
Enter the first number (degrees), ex:15
Press [2nd][APPS] (ANGLE) to access the Angle functions
Select [1: degree symbol] [ENTER]
Main screen shows 15 deg
Enter the minutes, ex 25
Press [2nd] [APPS](ANGLE) to access Angle functions
Select [2:' apostrophe] [ENTER]
Screen echoes 15 deg 25'
Enter the seconds number, ex 32
Press [2nd][+] (") to access the double quotation mark
Screen echoes 15 deg 25' 32"
Press [ENTER]
Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 06, 2010 | Texas Instruments TI-85 Calculator
HOW DO YOU USE THE DEGREES MINUTE SECONDS FUNCTION
To convert an angle from degrees (decimal degrees) to the sexagesimal notation (deg, min, seconds) use the key [DMS] the one between [(-) and [hyp].
Everytime you press the key, the displayed result is cast in the other form
EX; 12.58 [DMS] gives 12 deg 34 min 48 sec.
Suggestion: If you are doing many calculations with the sexagesimal format, use the decimal degree format, and only when you find the final result do you convert it to DMS.
Hope it helps.
Sep 30, 2009 | Casio FX-115ES Scientific Calculator
53 people viewed this question
jasbo
jasbo
