Question about Whirlpool Refrigerators
Plugged drain tube on model ET18NK/ET18NM - Whirlpool Refrigerators
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: have whirlpool ET18NK/ET18NM refrigerator-food
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 27, 2011
A briggs and Stratton 800 series engine. The only serial number I can find 1ho13k50009 It says the model number is 29a-672j711. Just wondering where the oil drain is to change the oil.
vertical shaft engines can have a drain plug underneath, in the side under the filler tube or on the other side opposite the filler tube
or you can drain the fuel out , then tip it on its side and drain the oil out of the filler tube
use an oil evacuation / filler pump to suck the oil out
horizontal shaft --plugs are near the filler tube , use the pump ,or tip it on its side
Oct 02, 2016 | Troy-Bilt Tb 672 208cc Ohv Gas Powered Jet...
Have whirlpool ET18NK/ET18NM refrigerator-food freeze in the center of frig and veggie bins--water collects in bottom of frig to overflowing if I don't keep a container in middle of top shelf to catch ...
Leo Ponder
imufo2
Sep 27, 2011 | Refrigerators
I have a whirlpool model # ET19RKXFW01 and it drains inside the frig instead of down the drain tube- i have had it unplugged foor over 24 hrs- how do i see if the tube is plugged ?
What has worked for me, is the use of a guitar string. Work it down the drain tube and then move it around to clear any clogs.
Jul 26, 2011 | Refrigerators
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Water is pooling in the bottom of the refrigerator. this model does NOT have an automatic ice maker, nor is connected to any water source. model #frt18g4awo
This is usually caused by the drain tube being plugged. There is usually a collector tray mounted under the refrigerator near the compressor and a small drain tube that runs into the refrigerator. The tube will plug with slime and green mold over time. Without knowing the model or make I cannot tell you for sure where the tray is located. If you find the tray you should see a tube laying into or hanging above the tray and running up to the refrigerator. Clean this tube and the little drain hole in the refrigerator with a pipe cleaner or soft piece of wire. Also check your door seals as a bad seal will also cause excess moisture to form in refrigerator, and children constantly opening and closing will also cause excess moisture to form and if the drain is plugged it will build up in the bottom.
Oct 07, 2009 | Refrigerators
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
Water under crisper in my whirlpool refrigerator
your refrigerator door may be (ajar) or drain clogged
Apr 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
