Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Audio This is a Sharp Aquous lc37d6u lcd. The tv audio comes on for a length of time and then suddenly cuts off. It will come on again if you turn it off and let is sit for an unspecified time (maybe an hour) but then goes out again in about an hour. Had direct tv technition check out the direct tv part of things and he and I believe it is the tv. Can you give me any suggestions? I have changed all of the cabling with no results. Dick D
  • 790 Answers
Re: audio
Maybe you have loose comtact to the main board! try to find them then resolder all parts in amplifier section! then check the voltage coming in to amplifier sec.
Posted on Sep 27, 2007
0 characters
3 Points
Opc sharp aquous no picture is coming up and opc light is this why its not working? none of the controls are working no menu is showing up. trying to fix it. is there any way to reset it?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 13, 2014 | Flat Panel Televisions
My Aquous 47" TV wont turn on
THe TV will not turn on and the opc button blinks green.
Jan 06, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquous tv has white lines running vertically like a pin-striped suit.
my 32 inch sharp Aquos has white lines running in the background of the screen
Jan 28, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquous Remote Codes
You can download the manual for the TV. It has all the code for the remote on page 90.
Here's the link:
LC-37G4U | LC-32G4U & AVC System Operation Manual (3900K)
Mar 31, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Brand new Sharp Aquous 37". I turned the tv on and a blinking green light comes and goes. I tried to turn it off and the blinking green light still on and no picture and no audio.
Behind your TV, there should be a system reset button.
If this doesn't fix the problem, most of the time this means a part has failed inside the TV. I would use the warranty and take it back and exchange it. You shouldn't be having this problem right out of the box.
I would have them check the new one so you don't have to waste a trip.
Good Luck
Feb 20, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Does the Sharp Aquous LC-13E1U receive digital or analog broadcas
It looks like your TV is not HDTV capable, so you will need a box when the conversion takes place next year unless you have cable box or satellite TV receiver.
Dec 20, 2008 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Dec 10, 2008 | Sharp LC-37D4U 37 in. LCD Television
T.V. turning on
yes my 26" sharp aquous LCD does the same thing, turns itself off and on at random times without explanation. I sent to authorized service center they replaced the power supply under warranty then it failed within 6 months and neither the repair center nor sharp will do anything about it other than sell me a new powersupply for $425.00. I have contacted a power supply repair center in Texas who has vowed to fix it once and for all. We'll see in the next week if they fix it or not.
Oct 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp lc37d6u
maybe you have lost connection.. or you have change value capacitors at the amplifier section! Step #1 resoldered all amplifier section! Step #2 Check all small capacitors with your ohms meter, or if you have no experience in this methods please go to authorize technician!
Sep 17, 2007 | Samsung SyncMaster 710MP 17 in. LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
60 people viewed this question
Top Sharp Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Sharp Flat Panel Television Expert? Answer questions, earn points and help others
