Question about Toys
My 2002 bmw 745i driver side window and both mirror won't work
  • 219 Answers
SOURCE: i need to change my oil and filter on a BMW
The oil filter is located underneath the vehicle next to the drain plugand accessed through a removable trim cover. If I remember correctly the drain plug is a 7mm allen. The oil filter has a drain plug in it to predrain before removing the filter cap. I do not recommend removing the plug because it strips out sometimes. Instead you need to use a socket and loosen the cap slowly. Your engine will take 8qts bmw syn 5w30 oil. I like the factory oil because it is proven extended life oil. When reinstalling the drain plug make sure to replace the crush washer. Also, make sure to replace the oring on the oil filter cap and lube before reinstalling.
Posted on Mar 18, 2009
tse22
  • 103 Answers
SOURCE: brake warning light is on for 2002 bmw 745i.
The brake pads have sensors in them, when the pads get worn down to the sensor the light comes on letting you know its time to replace. this happens well before the pads are completely gone to reduce wear on the rotors. You should have the brakes replaced and the sensor also.
Posted on May 17, 2009
  • 173 Answers
SOURCE: driver side door switches are not working,
Consult you manual for correct fuse applications and schematic for correct locations for your non-working components. Possible blown fuse.
Posted on Jul 08, 2009
  • 166 Answers
SOURCE: 2002 Ford Explorer - Drivers side door lock, rear
Aside from the fuses, your drive side power door lock may be failing to work because of a bad door-lock relay system, or, alternatively, the locking switch/button, itself, is not malfunctioning and in need of replacement.
A great handyman site that specifies the above probable causes and more is the following link:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Locks_Power_Locks_Do_Not_Lock_When_Pressing_Locking_Switch_Button.htm
Posted on Jul 18, 2009
  • 1810 Answers
SOURCE: 2003 Chevy Tahoe. Driver's side power window
check releys and wires in door jam 1 might be broken failing that u need a new switch
Posted on Jan 13, 2010
Rear view mirror
Have you opened up the door panel to see the wiring connections? Does the mirror appear to have a lighter color ring around the outside? If it does it is probably heated. The best way is to provide the VIN # to the local dealer who can tell you for sure. They should not charge you for this service.
Sep 16, 2015 | BMW Vehicle Parts & Accessories
Why cant i open my driver side door on my 2002 bmw 745i ?
If your exterior handle lifts up in a rocking motion, it could be the small rod and clip arrangement has become disconnected from the main lock actuator mechanism. This was a bear on my M3 to fix due to the limited working space near the handle. If you're comfortable with removal of the inner door panel, vapor barrier material and latching mechanism to attempt to fix be careful and good luck. Otherwise I'd suggest taking to a qualified body shop for assistance.
Aug 29, 2014 | BMW 745i Cars & Trucks
Bmw 745i problems
check your fader switch from front to back >>>>>>>>>>>mutebuttonon radio not switched on ...alternatively radio output or amplifier in car if fitted
Jan 13, 2014 | Cars & Trucks
My 745i has gas and batterty power but it will not start.
The 2002 BMW 745I has a recall when the gas goes under a third of gas it will shut off and not start cause it thinks it has no gas. You can call BMW and they will check if your car is on the recall list and you can get it fixed for free. Or they told me to just take it to the BMW dealership and tell them.
Nov 14, 2010 | 2002 BMW 7 Series
Need a drive belt diagram for a 2002 Bmw 745i
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/2002/make/bmw/model/745i/2002_bmw_745i_drive_belt_routing_diagram.htm
Dec 19, 2009 | 2002 BMW 7 Series
I need to tow a 2002 bmw 745i, i have a dead battery and can't put it in neutral
YOU need to take the KEY and JUST above the Hood latch is a place tofit your Key, Turn and a box filps down with a cord, pull the cord and it makes the gear go to neutral
Sep 18, 2009 | 2002 BMW 7 Series
How do I disconnect/remove the wiring of the passanger side mirror on my 2002 BMW 325 CI?
the mirror is easy, theres a trim panle on the inside of your car exact oposite the mirror (it's the mirror of were the mirror should be)
remove that and there you go.
To get to the Wireing you need to remove the door trim panle. do you know how to do that ? and do you have auto windows ?
May 30, 2009 | 2002 BMW 3 Series
Brake warning light is on for 2002 bmw 745i.
May 17, 2009 | 2002 BMW 7 Series
BMW 745I 2002 wiper dead
there are several things that can cause the wipers in your car not to work. if you have verified the fuses are good and verified power to your wiper motor, I would try disconnecting the negative battery cable for 15 minutes, then checking operation of the wipers. by the way, which fuses did you check?
Mar 24, 2009 | 2002 BMW 7 Series
Toys Logo
677 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
