Kodak i50 scanner error code 129 - Office Equipment & Supplies
2 Suggested Answers
s_4u_11
  • 535 Answers
SOURCE: Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Posted on Oct 21, 2008
Kodak U9 error code. How do you clear it?
we are facing problem Kodak i4600 scanner error u9 .we replaced udds Sensor same problem.
Aug 22, 2013 | Kodak Office Equipment & Supplies
Error Code 7 blinks for awhile then locks on error 7
HERE is the service guide for your printer. the error code you mentioned says to call Kodak support and gives no other info.
Jan 07, 2011 | Kodak i40 Path-Through Scanner
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
Error code: 1-2036
go to Kodak easyshare support:
http://www.kodak.com/global/en/service/products/ekn026079.jhtml?CID=go&idhbx=easyshareswsupport
In the box under Find Answers, type the complete error code (without spaces), then click Search. An error code should be like 12x413x1304x
Cheers
Jun 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing with a Kodak Esp 3
NO, not that I know of. I hate this too. My solution is to get a $50 trade in for a HP printer, scanner. check on line for HP trade in. There is one in effect now. You have to buy a printer that is at least $179 regulat price, even if it is on sale for 129, you can get the rebate.
My printer has had 3 printheads replaced, ink, I got 4 4X6 color prints and 85 black printed pages before the ink ran out. Kodak has bigggggggggggggggg problems with this printer.
Jun 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
121:SCANNER HOME
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Selected scanner was not found adobe acrobat
first downloaded the trial version of Acrobat 7.0 and removed
Acrobat 6.0. Test scanning ok it will worked!
Proceed to uninstall the Acrobat 7 trial version and
reinstall the 6.0 version you own, try this i hope it will work for you.
All d best
Mar 29, 2008 | Kodak Open Box i50 Flatbed Scanner
Kodak I-40 Scanner
8 Face up light check failure is the only code listed, not "88" for this model.
If code 8, the top lamp may well be occasionally flickering. Could be the Lamp or the Inverter (Ballast) check connections to lamp.
Jan 12, 2007 | Kodak i40 Path-Through Scanner
49 people viewed this question
jasbo
jasbo
