Question about Blackmagic Design CABLE-BDLKHDEXT Breakout Cable for DeckLink HD Extreme and Studio
Decklink HD Extreme breakout cable pinout - Blackmagic Design CABLE-BDLKHDEXT Breakout Cable for DeckLink HD Extreme and Studio
3 Suggested Answers
SOURCE: install failed when i install a decklink hd
i have not philips tv tuner card driver
pls driver download
Posted on Jun 26, 2009
anamariaramo
  • 20 Answers
SOURCE: I need drivers for Decklink Extreme
Try this site: http://www.blackmagic-design.com/support/ if this does not help you can try http://driverfinderpro.com/.
Posted on Apr 19, 2012
Apr 19, 2012 | Blackmagic Design DeckLink Extreme...
How can i caputer dv in blackmagic decklink hd extream 3d
according to your problem first check that you have installed the card in PCI slot correctly.
install the driver with all features. Set it properly. attach the jack & cables properly. Keep enable the dual stream 3D processing and HD option. It's HDMI automatically configures to connected display.
Follow the manual and start capturing.
Jan 14, 2011 | Blackmagic Design DeckLink HD Extreme 3D...
When ever i try to capture audio through xlr
whic soft ware are you using with blackmagic board Final cut or adobe primier
in mac go to system priferences and check for blackmagic is it set ok
and in pc go to controll pannel and you will find the blackmagic utilities please check also the setting nd also check the setting in priferences of the adobe primer and easy setup and capture setting in log and capture in finalcut if every thing is ok please download the latest software driver for the blackmagic board and install it it will *** a firmware upgrade and every thing should be cool .....
which board decklink extreem or the older one?
Apr 18, 2010 | Blackmagic Design DeckLink Extreme...
SW1000XG breakout cable port pinouts
HI,
Did you find the info you wanted on the SW1000XG card as I have the same problem and have been going round in circles.
RegardsBarry
Dec 07, 2008 | Computers & Internet
Capture video from composite input
you should make sure everything that may cause interference is away from any of those cables, such as cable/dsl modem, wifi router..etc because they cause a large amount of electromagnetic interference
Nov 02, 2008 | Pinnacle DV500 DVD Video Capture Graphic...
JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Apr 01, 2008 | JVC TH-C50 System
Blackmagic Design CABLE-BDLKHDEXT Breakout Cable for DeckLink HD Extreme and Studio Logo
201 people viewed this question
Top Blackmagic Design Televison & Video Experts
Electro Med Services...
Are you a Blackmagic Design Televison and Video Expert? Answer questions, earn points and help others
