Epson Stylus Pro 9600 InkJet Printer
Problem for Epson Stylus Pro 9600 InkJet Printer
Using the cutter
By Billybilly on Sep 26, 2007
Does anyone know if we can get the cutter on an Epson 9600 to cut sheet fed paper before or after it prints? We want to print long pictures without large vertical borders!
Thanks,
Billybilly.
Best Solution
posted on Sep 27, 2007
Very Helpful)
punker0204
Rank: Wiz
Rating: 84%, 101 votes
you want to print borderless on a cutsheet media? you just have to select and 'cheat' the printer in the printer properties, in there choose roll on the paper source option then enable the cutter and choose double cut on printer's set-up menu on the panel, then it'll cut before and after the printing to make it borderless from top to bottom and from edge to edge. just be sure that the cutsheet media is long enough so that the printer can still hold the media as it finishes the printing or else it'll be a waste, cause the printer wont finish the image. and take note that the epson sp9600 has a limitation in printing borderless, it'll only print borderless on (12", 17", 24", 36:, and 44") media size only i think there's also 14". trust me it'll work, ive done it! :P
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Pro 9600 InkJet
Questions and Unsolved Problems for Epson Stylus Pro 9600 InkJet
Do you recommend Epson Stylus Pro 9600 InkJet Printer?
Answer
Answer
printing stops when 98% done. Printing from Vista
Answer
Can't get to print past 55" We have printed other pieces that were longer. Tried resaving the... (More)
Answer
My boyfriend and I bought a 9600 secondhand and can't get into SM 2. We get into SM 1 find by... (More)
Answer
epson stylus 9600 rotating image for printing trying to print 20''x30'' image onto 24'' roll. need... (More)
Answer
can t seem to rotate image to print vertically: printing 20'' x 30'' image on 24'' roll. need to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus Pro 9600 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
