Question about Yamaha Ridgid Rd6800 6,800-watt Gasoline Powered Generator With Engine
My Ridgid 6800 generator has started idling at a high speed. This happens minutes after starting up .
3 Suggested Answers
SOURCE: engine idles fine with high beams on and bogs down with low beams
voltage regulator... just a guess, but better get it checked.
Posted on Jul 20, 2009
sisadsl
  • 1508 Answers
SOURCE: starts up good high idles misses messes around
should be more than 11.5v,, more like 13v running. If this only happened after a bath, check all the electrical connections, unclip the plugs and blow compressed air on them to dry them out. drain the fuel bowl as well by unscrewing the small screw at the bottom of the bowl.
Posted on May 10, 2010
Dolmar 6800
The idle speed should be NOT QUITE high enough to rotate the chain when the chain lock is not engaged. There should be NO adjustment for high idle speed.
Aug 06, 2014 | Dolmar 18" Power Match Chainsaw Bar .375"...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Immediately after I start my '07 Corolla the idle speed is around at 1,400-1,600. This generally happens in the morning or after work. When that happens if I I let it idle for five minutes it goes down...
This idle condition is normal for a cold start, the computer is controlling the idle for proper fuel burn. It is not necessary to wait five minutes for the idle to come down. Allow about one minute before putting into gear and driving.
Nov 04, 2010 | 2007 Toyota Corolla
Starts up, runs for 10 seconds sticks and pops circuit breaker
your motor start capacitor on the side case of the motor is bad,get it replaced before you ruin the armature from excessive heat generated from the motor not coming up to speed soon enough and drawing excessive current to try and keep it running
Apr 16, 2010 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
When I have it on it stays on high idle speed. When I push the auto idle it will not change the speed to normal. It idles at high speed all time.
If you have anything plugged into the generator, consuming any electric, it will run at high. It must run at high speed to generate 120V. It will only idle if your turn off the load.
Feb 13, 2010 | NEC Mitsubishi MGE 4000 Generator ROU...
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Need help with the needle valve placement on a Tecumseh Carburetor for a generator
Do you have the model and spec number for the engine?
Is it the high speed or idle adjustment?
Rule of thumb for high speed it turn in til snug and back of 1.5 turns; idle is 1 turn. Start engine and adj to ear.
Jan 02, 2010 | Coleman Powermate Powermate 5000W...
Idles to high to much power
It idle to high because to much fuel input in the carburator. Try to adjust the speed to required frequency 50 or 60 HZ ( it depend upon the country you are living ). You cannot start now because the generator have overspeed protection or over voltage protection that may trip & need to reset before you can run agin the generator.
Mar 19, 2009 | Coleman Powermate Powermate 5000W...
Yamaha Ridgid Rd6800 6,800-watt Gasoline Powered Generator With Engine Logo
52 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
