Toshiba 61HX70 61" Rear Projection Television Logo
Posted on Sep 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture red and green not lining up on my Toshiba 61HX70
The green and red aren't lining up on the screen, so we are getting double images of the picture. How can I fix this? Where is the best place to get the parts if needed?
Vista Electronics
Level 3:
Genius:
  • Master 1,694 Answers
  • Posted on Sep 26, 2007
Vista Electronics
Master
Level 3:
Genius:
Answers
1694
Questions
Helped
585033
Points
2786
Repair will require technical and mechanical skills.The red convergence IC will need replacement,which will require the chassis to be removed.After IC change,alignment in the servicer menu may be needed.Go slow--Remember, above all else,do no harm.You have a great tv,so my suggestion is get a senior tech on this one.
A friend bumped into my Toshiba 61HX70. Now the
Convergence is off. A tech can help resolve the issue.
I have a double image on my screen. When I push
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Samsung HCN4727W Rear Projection TV, green screen, audio works
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
1helpful
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Toshiba 50H81 projection television
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
2answers
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
