Question about Alpine PXA-H800 Digital sound processor
The best way to set up an pxa h800 - Alpine PXA-H800 Digital sound processor
I have a CISCO IP communicator phone and a logitech h800 phone. I can't pick up and end calls
I know this is a bit late answer, but i got these headphones a few days ago and found a solution for it :)
You can check my post here:
http://www.autohotkey.com/board/topic/90056-hotkey-logitech-h800-with-cisco-ip-communicator/
Good luck! :)
Apr 13, 2012 | Logitech H800 Wireless Headset Microphone...
How do i turn it on
Press and hold the "call" button until the indicator light turns on.
The call button is the half-circle/clear button directly above the motorola logo/indicator light
Mar 08, 2010 | Motorola Mobility H800 Wireless Headset
PXA-H700 optimum set up...
The way the EQ is hooked up is correct.
You set the factory radio to a set level, then use the volume on the EQ for everyday adjustments.
I believe your problem lies in the amplification.
Your BOSE amplifier was made to run a 4 channel 8ohm stero load.
Low powered - high in sound quality.
You have swapped the factory 8 ohm speakers (15W) for 4 ohm power hungry ones.
Now the amplifier is working harder to produce the same output.
You would be best served eliminating the factory amplifier and getting 1 good 4 or 5 channel amp to power your speakers.
a 4 channel amplifier could be used stereo (left and right) on channels 1 and 2, (2ohm stereo load)
and bridge channels 3 and 4 for your subwoofer.
For a true surround sound - a 5 channel amplifier could run each speaker individually, and the 5th channel is reserved for the subwoofer.
a small dedicated 75wx4 channel amplifier with built in crossover, and level gain controls - would blow your socks off. It is 200x better than the factory 12Watt amplifier. Your ears will love you for it :D
If you need more help - just let me know.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | Alpine PXA-H700 Car Video Player
Motorola H800 not powering up or showing blue ligh
Same problem here and i have exchanged a few times at the store already thinking i am doing something wrong and i keep getting the green blinking as soon as i hook the charger up but it isnt charging....anyone find a solution?????????? email me dorkfish2000@yahoo.com Thx
Apr 19, 2008 | Motorola Mobility H800 Wireless Headset
Alpine PXA-H800 Digital sound processor Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
