Question about Jabra Sport Bluetooth Stereo Headset - Black/yellow
Purple light - Jabra Sport Bluetooth Stereo Headset - Black/yellow
Tip
Solution to the HP Purple Web Cam Issue
This document is located on HP's web site concerning purple tint on certain web-cams.
This document pertains to certain HP Notebook PCs with Windows 7.
When using an HP ENVY 15 notebook PC webcam in low light conditions, images on the webcam may have a purple tint.The ENVY 15 Series webcams include night vision technology that is designed to operate in normal lighting conditions and optimized to operate in low and zero light conditions.The webcam night vision feature includes two Infrared (IR) lights located on each side of the webcam and behind the display panel bezel.
Low to zero light conditions will cause the webcam IR lights to activate. The IR lights provide illumination for low and zero light conditions and help prevent fuzzy images that are typically associated with operating standard webcams in low and zero light conditions.
Turn off the webcam IR lights. While some degree of purple tint may be present under low light conditions, turning off the webcam IR lights will reduce and in certain cases eliminate the purple tint.
  1. Select Start > All Programs > HP > HP MediaSmart > HP MediaSmart Webcam .
  2. In HP MediaSmart Webcam, select Settings > Display > Advanced Settings , and then click the Camera Control tab.
  3. Select the Low Light Compensation check box, and then click Apply .
  4. Click OK .
NOTE:Disabling the webcam IR lights will cause display images to appear darker in low and zero light conditions.
The webcam IR lights are also available on other webcam programs.
Refer to the software Help for additional information.
This document will be updated if additional information becomes available.
on Jul 28, 2010 | Computers & Internet
Emerson em511 showing a purple light
the purple light is the link up light to your componte
Jan 22, 2013 | Emerson EM510 Stereo Wireless Headset -...
Purple indicator light
Can you hear the Hardrive whirring, are there any messages on screen, or is it just dead with a purple light on.
Dec 18, 2012 | Gateway ProfileĀ® 6C (PROFILE6C) PC Desktop
I have a 3 speed hampton by fan. i'm trying to change the fan switch. i bought a westing house switch and have trouble wireing it. the fan has 4 wires blk purple brown and white.
The black wire should go to one side of the switch, and either the purple or brown wire would go to the other side. The fan is run by either purple or brown, and the light by the other color. If you have no light, then the wire that would go to the light should look unused. Try one, then the other if you guess wrong.
Turn off the power before connecting the wires.
Good luck.
Jan 06, 2010 | Westinghouse Electric Westinghouse...
H700 Motorola Bluetooth Headset
Make sure that any devices previously paired
with the headset are turned off. If the indicator
light is flashing in blue, turn off the other device,
then close and reopen the headset boom. The
indicator light becomes steadily lit in purple
indicating the headset is now in pairing mode.
Jan 03, 2010 | Motorola Mobility H700 Wireless Headset
Old pink and purple bathroom needs help.
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
Motorola H700 will not pair with LG VX8500
Close boom press call button till light turns purple then instantly open boom, ta da, you just forced it into pairing mode! The purple light will be steady untill you finish pairing the two devices.
Feb 03, 2009 | Motorola Mobility H700 Wireless Headset
Motorola H700C - purple light
its on paring mode that means that its ready to be pared up with the phone.i would just close it to turn it off and reopen it and connect
Jul 17, 2008 | Motorola Mobility H700 Wireless Headset
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
Jabra Sport Bluetooth Stereo Headset - Black/yellow Logo
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
