Question about Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
Re: SMEG Integrated Dishwasher ST663. I'm having difficulty getting the dishwashing program to start - requires considerable inwards pressure at the top of door before cycle starts. It seems as though the door closure latch needs adjusting, so how do I do this? Regards, Ken Tuckwell 18Oct2013
  • Kenneth Tuckwell
    Kenneth Tuckwell Oct 20, 2013
    Solution worked a treat - thankyou!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Posted on Oct 18, 2013
  • Kenneth Tuckwell
    Thanks, now works fine. I was on the right tram, but adjustments initially too big a bite.Your help much appreciated.
I cleaned out the filter on my Smeg integrated dishwasher, model D16012, yesterday then started a fully loaded cycle. The items were all clean when I unloaded but some water remained in the bottom of the...
It may be possible that something fell out of the filter and into the drain pump. The machine will do a short drain cycle at the start of a program and if it is jammed or blocked, this will cause this problem.
Jul 02, 2014 | Smeg Dishwashers
How do i fit smeg integrated smeg dishwasher
Not sure I understand the question. Are you asking how you fit your new dishwasher into the old dishwasher's hole, or are you asking how you get the actual measurements of the dishwasher because you're building a new set of cabinets and need to build it to fit?
Sep 02, 2012 | Smeg Dishwashers
HOW DO I DRAIN WATER FROM MY SMEG DISHWASHER
There is a screen filter at the bottom of most dish washers, if the screen gets dirty it probly won't drain properly. Check the screen and clean if neccesary. If not that, then pump may be getting weak.
Jun 25, 2012 | Smeg Dishwashers
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
Apr 26, 2009 | Smeg Dishwashers
Smeg Dishwasher
replace the timer/control board
May 26, 2008 | Dishwashers
SMEG INTEGRATED DISHWASHER FLOODING
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Nov 18, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
234 people viewed this question
Top Dishwashers Experts
Owen Barnes
