Question about Campbell Hausfeld 04 Gallon Twin Stack Compressor HL5502
It stopped working does it have a fuse if so where?
How do i find wiring diagram for stop lights
The STOP LP 25 A fuse in the underhood fuse block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both the STOP 15 A fuse and the CHMSL 10 A fuse in the I/P fuse block, and to the turn signal/hazard module. The turn signal/hazard module then supplies voltage to both of the trailer rear turn/stop lamp supply voltage circuits. The voltage from the CHMSL 10 A fuse is to the center high mounted stop lamp (CHMSL) and the trailer jumper harness. The voltage from the STOP 15 A fuse is to the stop lamps, throttle actuator control (TAC) module, and the cruise control.
Do you know what a stop lamp switch is ? If so I would check it with a DVOM digital volt ohm meter , after you check fuse .
Did
Nov 05, 2015 | 2005 Chevrolet Chevrolet Avalanche 1500 LS
1994 Toyota Corolla keeps blowing the "stop" fuse....
No idea. Maybe it is telling you to STOP replacing the fuse. Just kidding as I would have to look into it but not working at the shop today as it is Sunday.
Mar 26, 2014 | 1994 Toyota Corolla
I am having problems with my emergency flashers working as well as my parking lights and turn signals. I've replaced fuses but they only work for about 30 seconds after I replace the fuses.
double posted, answered today , backup one.
fuse 34, see that?
login to alldata.com and read the BCM diagnose page.
see fuse 34 , the hot all time fuse to BCM... its blown,
fuses blow to prevent a fire. so do not be tempted to put in a bigger fuse. or you get,. yes, BOOM (4th july)
Feb 06, 2014 | 2007 Jeep Liberty Sport
All 3 cig lighters stopped working on 1997 infiniti q45
Hi Jal, I would think all 3 lighter are on the same fuse. There must be another fuse box inside the vehicle,possibly in the kick panel area.
Dec 29, 2013 | Cars & Trucks
Cigarette liter stopped working then the next day the blower motor stopped working, Now the buzzer for head lites being left on stopped working and interval wipers stopped as well. This has been within a...
no power, means, what, cig lighter plug dead,?
try something else there, like a cell charger, still dead.?
if it is truely dead, the fuse is blown.
does head lights work, and engine run?
ok fuses that bad are bad, blown. (blown elements)
ok fuse that look GOOD, can in fact be bad, (tiny cracks.)
we never fail to test good looking fuses or go nuts for sure.
you can test fuse 3 ways.
1: DMM ohms, 0 ohms reading
2: voltmeter shows, 12v, on both sides of fuse, key on.
3: a fuse tester dealy bob at any autostore. (ill pass)
there are other ways, but are way too complex to type.
(ok a battery powered test light , yes, all auto stores sell them.
glow with a good fuse)
bingo?
Sep 03, 2013 | 1991 Honda Accord
Nissan Xterra Brake Light Fuse Location
It's 15A FUSE 39 in the fuse & fusible link box
Mar 25, 2017 | Nissan Xterra Cars & Trucks
Whirlpool over the counter microwave stopped working
SEE THE steps and fix it. and diagrams attached.use the DVOM.God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown2_6_2013_8_43_03_pm.gif2_6_2013_8_43_37_pm.jpg
Feb 06, 2013 | Microwave Ovens
Bmw speedometer
Sounds like a bad or lose fuse. Take a look in the fuse panel and look for a loose fuse or blown fuse.
Jan 10, 2013 | 1993 BMW 325
Door locks stopped working.
you maybe a short somewhere. if the fuses keep blowing then you have a positive cable somewhere touching ground
Apr 17, 2009 | Jeep Cherokee Cars & Trucks
2003 silverado 1500 v-6 brake lights dont work
ljones, Did you check the "VEH stop" fuse in the left side instrument panel fuse box. There are 3 stop light fuses, 1 for all the stop lights located in the under hood fuse box. 2 in the left side IP fuse box. 1 for the upper stop light and 1 for the lower stop lights. The fuse box in the IP is where the upper and lower stop lights split. Let me know.
Feb 26, 2009 | 2003 Chevrolet Silverado 1500
Campbell Hausfeld 04 Gallon  Twin Stack Compressor HL5502 Logo
23 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
