Question about Vizio 47 E472VL 1080p 120Hz Widescreen LCD HDTV - 100000:1
What is wrong with vizio e472vle will not power on? how can I tell if it is the fuse just by looking at fuse?
Can I fix my vizio e472vle? Or do I need to purchase a new tv? Any Idea what i would need to repair the problems listed below (flciker of menu and smart functions).
Follow these steps to reset your TV:
  1. Unplug power to your router.
  2. Perform a Clear Memory or Reset to Default on the TV.
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
  1. Plug power back to router.
  2. Perform the setup process and reconnect to your network.
Jun 02, 2017 | Vizio Televison & Video
I have a Vizio E472VL television. When I go to turn it on the logo appears on the screen and the "vizio" icon back light turns on, but nothing else happens. I have tried coax, component, HDMI, etc..
Had the same thing happen to my Vizio TV. It was on warranty, and they replaced the motherboard. It's been fine since then. There appear to be only a very few parts inside. Power supply, motherboard, and display. That's it. Your power supply is good, as is your display. You just need a motherboard.
Jun 09, 2015 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Tv will not come on. I have unplugged it waited 30 min an nothing.
those model have a common problem on the power supply
you can find one here :
http://www.bostonrecycling.net/lang/965-vizio-0500-0412-1220-power-supply-backlight-inverter.html
its plug and play, easy to do...
let me know if need more help
Oct 16, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Vizio E472VL has sound but no picture
TRY THIS LINK .... http://www.ehow.com/list_7461529_reasons-power-but-picture-sound.html
Oct 17, 2013 | Vizio VO47L 47 in. LCD TV
VIZIO E472VLE Will not power on.... I have changed the power board and the main board but it will not power on. Does anyone have a schematic for this TV?
First check the inverter boards,if inverter boards is defective,you also could not turn on your tv.
if not you need check main boards,
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Sep 26, 2013 | Vizio 47 E472VL 1080p 120Hz Widescreen LCD...
No audio out for surround sound on vizio e472vle?
I would check the owner manual and call Vizio but if the set does not have the correct outputs it will never work for that.
Jun 11, 2012 | Vizio VL Televison & Video
Vizio 47 E472VL 1080p 120Hz Widescreen LCD HDTV - 100000:1 Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
