Watches Logo
A
Anonymous Posted on Oct 18, 2013
Refill and flint change on piere cardin lighters
Do you repair calibri lighters
We are FIXYA dot com, we aren't Colibri, we just has a Colibri section for handy filing. We only supply information.
https://www.google.com/search?q=colibri+electro-quartz+lighter+repair
Customer Service - Colibri
https://colibri.com > pages > customer-service
What do I do if my item arrives damaged? Your complete satisfaction is our goal at Colibri.com. Please contact a Colibri.com service representative at (212) 308 ...
Where can I purchase a flint chamber for a gold plated Swiss made?
Indistinct query and guessing this is a lighter and not a Watch which is the Category you are in.
The Google search query would be
make model parts
https://www.google.com/search?q=flint+chamber+for+a+gold+plated+Swiss+made
How do I change the flint on my Cartier lighter?
I am not familiar with this particular lighter, however, changing flints isn't usually difficult. Could you post a photo of the underside of the lighter? Try turning the lighter upside down. There should be two sections moulded in the bottom of the lighter. One is the refill port you use to fill it with gas, the other will be the adjuster or mount for the flint. The flint holder is usually a Spring loaded tube with the flint mounted at the top end. Carefully unwind the screw or twist cap being careful the spring doesn't suddenly release. This should slide out letting the remains of the old flint fall out. You may need to GENTLY tap the lighter to knock out any dust left by the old flint. Insert the new flint, insert the retaining pin and screw it in until it is finger tight. Screw too tight and you could crush the new flint or damage the screw thread on the retaining pin.
2answers
Colibri cx gear 35002 butane lighter
I.ve got a lighter its silver crome alluminum it reads on both sides a big X with a c on top and us on bottom its butane on the bottom it has a signiture I.D it looks like a snake going up a stick can you help me idenify this lighter it's driving me nuts Thank You Lily
Sep 22, 2012 • Watches
2answers
Flint spring & screw for monopol lighter
mcdevito75 here, Best Bet, Shop ebay for a similar lighter, flints you can buy at most stores that sell cigarettes.
1helpful
How to fit a flint in a vintage dunhill pistolttable lighter?
On the underside opposite the flint there should a screw head.
Remove this screw (take care, there will be a spring inside!) .
Turn it over and the remains of the old flint should drop out.
Insert new flint and re-assemble.
Jan 16, 2010 • Watches
11helpful
I had Cartier lighter gold.But ran out fluid.Can u show me how?Thanks
I have a cartier ligther that the striker wheel turns freely, no flint can enter the upper channel so I am thinking some old flint or somthing is obstructing the channel. How do I fix it or clear the channel?
12helpful
Refilling a dunhill lighter
All rechargeable lighters have a refilling nozzle (usually at the bottom of lighter).
All the good quality gas refill cans have the nozzle adapters inside sovering cup.
Brake off the nozzle adapters off the cup and try to fit them onto lighters refilling nozzle.
When found the best fit adapter, put it onto gas refill cans nozzle and holding the lighter and can upside down connect all nozzles together and push together.
As these nozzles are made for mass production lighters, tey do not fit perfect and some gas leak will occure.
Anyway- few seconds will be enough to refill any lighter.
In case if your lighter do not refill by explained action, the refill nozzle in your lighter is damaged or faulty.
Hope it does help.
Do not forget to rate, please.
4answers
Dunhill cigarette lighter spare parts needed
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn [email protected]
Jan 30, 2008 • Watches
Top Pierre Cardin Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Pierre Cardin Watch Expert? Answer questions, earn points and help others
