Question about Cell Phones
Why is my wagon heating up?
Temperature gauge goes up when wagon goes up hill, seems to be when extra rev's kick in
    Problem Solver:
  • 9 Answers
Check oil level and coolant levels. If both are good you may need to change the thermostat on your radiator. If it is old it could be getting stick.
Posted on Oct 18, 2013
The heat come on and then goes off and also the needle goes up to hot and come back down
Engine Temperature Issue - Please Help! - Mazda 6 Forums : Mazda 6 ...
forum.mazda6club.com > ... > Mazdaspeed6
Sep 12, 2011 - Join Date: Mar 2006 ... to the gauge) and then after being shut off for 5 minutes, show COLD. ... I'll also confirm, with my AP, that my ECT is around 200 like it normally is. .... VSS, and ECT signals and calculate radiator's heat the radiation ... I noticed my engine temp needle was dipping down and then came ... CEL - Throwing code P0126 (Insufficient Coolant Temperature ...
Nov 18, 2013
Temp gauge needle
Mar 14, 2013
overheating problems
Jun 5, 2010
Temperature Gauge
May 22, 2010
More results from forum.mazda6club.com
Temperature gauge going up and down - CarGurus
www.cargurus.com > Questions > Infiniti > I30
CarGurusAug 20, 2014 - Also as my temperature gage rises but car does not overheat. ... tempneedle gets up towards the red mark while you're driving, then yes, ... i have a 2006Pontiac Grand prix and my temp. goes up to the ... crzgrl637 answered 6 months ago ...the cooling fans won't kick on then you will see gauge over heat.
Car Engine Overheating - Causes and Symptoms of Over ...
Jan 17, 2016 | 2006 Mazda 6
2010 Aveo 5 speed. Temperature guage quit working. Indicator needle doesn't move. Heat works just fine. No change in needle indicator whether heat is off or on. Service manager booked solid. Says not to...
He is right about that. The sender unit for the dash gauge is only for the gauge. Another sensor, the coolant temperature sensor, conveys information to the computer about the coolant temperature, and if fans need to be turned on for extra cooling.
Sep 23, 2013 | 2010 Chevrolet Aveo
Cefiro '97 2,5L over-heating. I bought this car yesterday and drove it home 200kms away. At about 150km the temp gauge showed high temp and I stopped for the night. This morning the radiator was
This may be an electrical issue in the dash and a phantom problem. I would suggest measuring the water temperature in the radiator to see if it matches the guage (normal temperature should be around 90decC. Higher revs would increase water flow via the water pump not lower it so I am thinking some kind of restriction - check your radiator fins are not blocked there could be blockages in the radiator or less likely in the block valleys, other things to check are that your hoses are in good condition and they don't flatten with heat. A faulty thermostat is also possible.
Feb 22, 2013 | Nissan Cefiro Cars & Trucks
Mitsubishi triton mk 1999 overheating
There might be a hole on top of radiator the air pressure bilds and will not flow through the engine the car overheats CHECK radiator for leaks with a radiator pressure test
Jan 19, 2013 | Cars & Trucks
Replaced broken water pump, replaced thermostat, and the temperature gauge consistently sits just below red once it's warmed up. It never seems to go into the red if I'm idling or taking short trips, but...
hi the temp gauge should sit in the lower quarter of the gauge, it has to be a faulty water temp sensor as anything else would cause it to over heat badly
Apr 01, 2011 | 1987 Subaru Gl 4WD
My 2002 xterra has started running hot..code po 217 came on..after gas cap was put on wrong..cleared code put gas cap on right then fine for 2 weeks..when idleing heat gauge rises high..as soon as i rev...
Hi Code P 0217 does point to the thermostat but it also points to the wiring, cooling system, and the temperature sensor, to check the thermostat start engine then once the temperature gauge in the car reaches normal the thermostat should open and the top hose that goes into the radiator will warm up quickly as the thermostat opens, if the thermostat is stuck in it's open position the top hose will start warming up before the engine reaches it's working temperature, hopefully i have explained it clearly,
Mar 17, 2010 | 2003 Nissan Xterra
Having a temperature question/problem. 2005 Jeep grand cherokee 5.7L Hemi 4x4 49,000 Miles. The temperature gauge plays around a lot. goes from the little bar before half temp. to the little bar after...
It sounds normal, but perhaps the radiator is a little small. Make sure the core is clean by blowing it out with compressed air (from the engine side) to clear out bugs and other debris. Make sure the overflow/reserve tank is at the proper level. Check the coolant level in the radiator when engine cold--it should be right at the top of the filler. These are all preventive, not a cure for anything.
Sep 17, 2009 | Jeep Grand Cherokee Cars & Trucks
Temp gauge goes into RED at 3000 revs and/or under load/acceler..
sounds more like a weak spring in the thermostat....not keeping the thermostat open fully under high water flow (like in higher rpms)
Feb 22, 2009 | 2000 Ford Focus
Overheating
please replace the thermostat
Dec 03, 2008 | 2003 Kia Sorento
1996 engine coolant problem
you can open the radiator cap before starting your engine and let it worms up and you can see by looking in to the rad if you have circulation maybe you will have to rev engine just a little if the new thermostat work it will circulate godd and check to make sure fan does come on new sensors but fan may be the problem be cautious as it gets hot . and also make sure there is no air in the system with the cap off and little rev if air is present it should come out good luck
Jul 03, 2008 | 1997 Toyota Celica
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
