Question about Vizio VO47L 47 in. LCD TV
Vizio e472vle will not power on
  • Vizio Master
  • 1,212 Answers
Unfortunately the T-con board is bad. Just so you know, the power supply and signal (main) boards are good. The T-con (Timing Control) board is part of the panel (screen) you would have to replace the panel (screen). This is not cost effective. You will need to purchase a new TV. Thanks for asking, Matt of Martins TV.
Posted on Feb 04, 2016
  • 21 Answers
Are you currently able to push the Device Selector Slider all the way to the right, into the TV position, and Press Power, to turn the TV On or Off? If not, go back to the first 2 or 3 Codes in your list (or the one the Installer selected, if he wrote it down) and see if you get AT LEAST that functionality out of the DTV Remote. One of the Codes will usually do that much, if you can get it to control volume, but not ALL of them: volume control, like many functions, may remain the same through several changes in Remotes, for many manufacturers. Don't forget to push the Slider back over to the standard DTV position, after you turn on the TV, or you'll change channels on the Vizio, and then you'll have to reselect DirecTV as your Input Source. :-)
As to finding the best possible Remote Code, for whatever reason, DTV's Online Remote Code Lookup Tool, and the Built-in Code Lookup often list Codes not found in the other. On top of that, If you call DTV Customer Service, after you've exhausted these other sources, and armed with your list of previously tried Codes and their results, in my experience, they often have 1 or 2 Codes I haven't come across, which will sometimes work.
I know this is kind of frustrating process, but hopefully it will be worth it. And being able to Power your TV via the Slide Selector is a decent fallback, even if you can't get it to work from the On/Off keys. I hope that helps.
Posted on Oct 18, 2013
Can I fix my vizio e472vle? Or do I need to purchase a new tv? Any Idea what i would need to repair the problems listed below (flciker of menu and smart functions).
Follow these steps to reset your TV:
  1. Unplug power to your router.
  2. Perform a Clear Memory or Reset to Default on the TV.
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
  1. Plug power back to router.
  2. Perform the setup process and reconnect to your network.
Jun 02, 2017 | Vizio Televison & Video
I have a Vizio E472VL television. When I go to turn it on the logo appears on the screen and the "vizio" icon back light turns on, but nothing else happens. I have tried coax, component, HDMI, etc..
Had the same thing happen to my Vizio TV. It was on warranty, and they replaced the motherboard. It's been fine since then. There appear to be only a very few parts inside. Power supply, motherboard, and display. That's it. Your power supply is good, as is your display. You just need a motherboard.
Jun 09, 2015 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Tv will not come on. I have unplugged it waited 30 min an nothing.
those model have a common problem on the power supply
you can find one here :
http://www.bostonrecycling.net/lang/965-vizio-0500-0412-1220-power-supply-backlight-inverter.html
its plug and play, easy to do...
let me know if need more help
Oct 16, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Vizio E472VL has sound but no picture
TRY THIS LINK .... http://www.ehow.com/list_7461529_reasons-power-but-picture-sound.html
Oct 17, 2013 | Vizio VO47L 47 in. LCD TV
VIZIO E472VLE Will not power on.... I have changed the power board and the main board but it will not power on. Does anyone have a schematic for this TV?
First check the inverter boards,if inverter boards is defective,you also could not turn on your tv.
if not you need check main boards,
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Sep 26, 2013 | Vizio 47 E472VL 1080p 120Hz Widescreen LCD...
Purlpe line down the middle of my vizio sceen
a number of possible reasons: bad connection from a board to display panel, a bad connection inside the display panel, a defective board that drives the screen and a number of other reasons none of which are easy to find or fix.
Aug 27, 2012 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
No audio out for surround sound on vizio e472vle?
I would check the owner manual and call Vizio but if the set does not have the correct outputs it will never work for that.
Jun 11, 2012 | Vizio VL Televison & Video
Vizio VO47L 47 in. LCD TV Logo
79 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
