Question about Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger
How do I tell when the battery charger is working?
My LG 4GLTE Model LG-VS920 does not turn on at all. It showes no signs of it charging or anything please can someone tell me what may be the issue?
Well either your charger isn't charging it or the battery is cooked . I would say your charger isn't working because batteries go bad but usually after a period of time. Not only that a charger will let the phone come on even if the battery is really low. Try another charger and if it continues your battery is done. Yo be sure take it to your carrier and they will tell you for sure
Jul 02, 2015 | LG Cell Phones
It keep giving me a message to plug in my charger because my battery is going dead so i bought a new dell charger the original one that goes with the netbook, and it worked for awhile, but now its telling...
it might be the battery, i had the same problem with my netbook the charger is ok but the battery died i can use it if it is plugged even if the battery is dead.you can tried taking the battery off the netbook if it turns on the charger is ok.
Sep 13, 2013 | Dell Inspiron Computers & Internet
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Wont turn on
Please unplug the battery (remember to disconnect the charger),
then, hold on the power button for a minute,
after that, connect the charger, and try to power on the laptop.
If it didn't work, you need to visit the technician
If it worked, disconnect the charger and connect the battery
If it worked, things are going well.
If not, the battery have problem.
Please tell us the results
Regards
Nov 12, 2011 | Sony VAIO VGN-FJ270/B Notebook
I have a golden 3 wheel scooter dose charger
If the charger is working correctly, it should turn itself off automatically (may go into float chrarge depending on type of charger). There should be an LED or an amp meter on the charger to tell you when the charge is complete. When the batteries are charged, you should be able to leave the charger switched on and it should cause no harm UNLESS the charger is faulty, in which case it will continue charging and damage the batteries. You should be able to tell if this is happening as the batteries will become very warm. If the batteries are losing their charge after you have switched the charger off, it is most likely that your batteries need replacing. Failing that, you may have a short somewhere which unfortunately, could be difficult to find.
Mar 10, 2010 | Electric Health & Beauty
Will not power on . I cannot turn on my Mintek. .
Well first of all tell me is your player works with charger or it never works..? If your player work with charger and not in battery mode then you need to change the battery in your player. if this not work with charger then may be the charger is bad and do not allow to charge the battery and never works...... Please reply for more help or information.....
Thanks
Jan 30, 2010 | Mintek MDP-1030 Portable DVD Player
Charing my battery for a FireStorm 9.6V
Yes, it means the charger is not working. The light is the charge indicator and is red while charging.
Nov 05, 2009 | Drills
Battery will not get any charge
Cell phone batteries are only good for about 300 charges then they go kaput. Take your charger to the store and try it there likely just a bad battery. Or a faulty charger, they will be able to tell you at US Cellular they have test equipment that they can check the battery and the charger and the phone charging circuit, I've never been charged for that service.
Jun 03, 2009 | Cell Phones
Cant find a kid trax battery charger
Here 12V Battery Charger for Kid Trax Riding Toys Dodge Ram Dodge Charger... you can purchase the charger from amazon. I hope this was helpful. Have a nice day
Apr 19, 2009 | Toys
15 MINUTE AA CHARGER
Call duracell and explain your problem they will likely send you new batteries. They will tell you that yours are old.
Duracell if the the USA (800) 551-2355
Aug 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger Logo
22 people viewed this question
Top Worx Garden Experts
Tim Whalen
Wayne McNeil
john milligan
Are you a Worx Garden Expert? Answer questions, earn points and help others
