Panasonic remote Hi, I have 2 panasonic remtoes N2QAYB 000341 & N2QAYB 000133, some of the buttons no longer work, example the OK and play button. Can you help me.
SOURCE: buttons on front console no longer work.
NO!!!! This dvd player has a KeyLock function which can be accessed by the remote which came with the player. Try to turn the keyLock off it should help.
Posted on Jun 09, 2008
SOURCE: DMR-E85H Remote is malfunctioning
i can supply you with one if you are intrested?
Posted on Dec 10, 2008
stonephoenix
  • 563 Answers
SOURCE: philips universal remote not working for my coby dvd 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
SOURCE: Coby dvd 514 remote
the code for coby dvd slim model 514 is 1812
Posted on Jul 28, 2009
tariq_romy
  • 116 Answers
SOURCE: remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
Posted on Feb 19, 2010
How do I program video 1 & video 2 on the remote
You do not program them; you access the A/V sources connected to Video 1 & and Video 2 by pressing on the Source/Input button on your TV's remote.
Feb 21, 2015 | Televison & Video
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
My n2qayb remote just stopped working . I don't know what I pressed. I put brand new batteries and still isn't working! Help it's only 10 months old.
MY PANASONIC REMOTE STOPPED WORKING I WAS JUST ABOUT TO BUY ANOTHER FROM AMAZON BUT DECIDED TO SPRAY THE FACE WITH CONTACT CLEANER WIPED IT CLEAN AND IT WORKS A TREAT. I SUPPOSE WD40 WOULD DO THE SAME. PAUL
Oct 05, 2010 | Panasonic Televison & Video
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Comcast remte code needed
20591, 20675, 20821, 21268,10154, 10236, 10463, 10180, 10178, 10171, 10623, 11963 if you have a remtoe with a GREY ok/select button these are the codes for the dvd players and combo units i had to use a dvd code for my combo
if your remote has a RED ok/select button use these codes 20591, 20675, 20821, 21268,
May 05, 2009 | Emerson EWD2003 DVD Player/VCR
Panasonic Dmr es35v VCR/dvd recorder 'Set 1' problem
Feb 10, 2009 | Panasonic DMRES15 DVD Recorder
I need the region dvd code for my panasonic triple play tv
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Nov 11, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Televison & Video Logo
Top Televison & Video Experts
