SOURCE: printer keep restarting. c6180 hp photosmart
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time.
SOURCE: HP Photosmart C4680 prints only
Make sure in the printer properties it is not set to print in b&w only.
SOURCE: need users manual for hp photosmart c4680 printer
Hi
Download the manual from the link below.
h10032.www1.hp.com/ctg/Manual/c02240492.pdf
Hope it helps.
Testimonial: "thanks for the download i have already found the manual keep up the good work"
