Question about General Electric Profile PGS908 Range
GE Gas Range Model PGS975 Oven won't light but broiler works fine and stove burners work too
4 Suggested Answers
  • 53 Answers
SOURCE: Oven will not light - top burners and broiler work
I would first check the amperage of the igniter. If the igniter is pulling the amps it should then the problem is the gas valve. In my experience the igniter is usually the culprit. They are not difficult to change just make sure you unplug the oven because some times there is live voltage on these wires.
Posted on Jun 22, 2010
Testimonial: "thank you. good advice and warning about unplugging the oven. very helpful."
heatman101
  • 43501 Answers
SOURCE: My PGS908 or PGS975 GE
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Feb 02, 2011
MNTECH
  • 1543 Answers
SOURCE: My GE PGS975 DEP1 (GAS
Power supply in Brazil is not universal over the entire country. Your range was built for 120 volt, 60 Hertz power supply. If you are in some areas, you may not have the proper voltage available. 127 V found in states of Bahia, Paran? (including Curitiba), Rio de Janeiro, S?o Paulo and Minas Gerais (though 220 V may be found in some hotels). Other areas are 220 V only, with the exception of Fortaleza (240 V).
Brazil does use 60 Hetz, but if you are in an area which only supplies 220 or 240 volts, you would need some type of adapter to convert that to 120 volts for your gas range. If you connected to the higher voltage, you may have irreversably damaged the electronic control, requiring control replacement, before connecting to the proper (120 volt) supply. I would expect 127 volts to operate your range, but if the voltage varied up from that, it could damage the control. Even in the US, voltage variations of 108 to 125 are rather common.
Posted on May 22, 2011
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
Ge gas/prop stove bottom oven burner will not light.Broiler and stove top burners work fine
you will neeed a new ignitior
its a pretty easy repair
take out the racks
take out the bottom of the oven
you should see the ignitor
pull ou the drawer you will see the connection
disconnect it
make sure your very careful with the new one they are very brittlle
Oct 09, 2009 | GE JGBP28 Gas Kitchen Range
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
General Electric Profile PGS908  Range Logo
145 people viewed this question
Top General Electric Kitchen Ranges Experts
Craig Butler
Craig Butler
reliableservice
DROPNDEAL
DROPNDEAL
Are you a General Electric Kitchen Range Expert? Answer questions, earn points and help others
