Question about Honda Vertical Engine 6.5 HP OHC 25mm x 3-5/32 GSV190-S3A
My billy goat ENGINE 6.5 HP HONDA GSV190 started white smoking so I killed it and it wont start
  • 1388 Answers
SOURCE: Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Posted on Nov 29, 2008
  • 84 Answers
SOURCE: 2000 honda accord ex v-6 3.0 engine........won't start in hot wea
replace main relay
Posted on Jun 25, 2009
Testimonial: "good call right on the money......thanks"
  • 291 Answers
SOURCE: 1986 Honda Civic overheating and blowing white smoke
what does white smoke smell like.. if antifreeze you have blown head gasket...does not sound good
Posted on Oct 10, 2009
sisadsl
  • 1508 Answers
SOURCE: CBR 1000rr wont start
check for spark, make sure the test plug is grounded to the engine or it can damage electrics
Posted on Apr 12, 2010
deanhornberg
  • 9 Answers
SOURCE: my 97 honda accord is blowing white smoke and running rough then i went to start it now it wont start
Sounds like either a blown motor (rings need replaced) or a bad head gasket or cracked head.
If the rings are bad your car would have felt like it was losing power because the engine will no longer have the same high compression that it's required to turn the wheels. You may have heard your engine knocking or seen a light blue colored smoke coming from your exhaust as a result of your engine burning up oil in the combustion chamber from the rings leaking.
If your head gasket is leaking or your head is cracked you'd likely find milky looking oil when you drain your oil from water/antifreeze being mixed in and noticed a white smoke coming from your exhaust that is actually water vapor coming through the exhaust.
If your car was running rough when you last shut it off try pulling all of your spark plugs and either cleaning them or replacing them all. A bad head gasket or bad rings can both foul spark plugs. A car will run rough with 1 or 2 fouled plugs, but once enough foul it will no longer run at all just sit and crank over. If changing the plugs get's it started for ya, check your tailpipe first for water, if nothing, change your oil. If no signs of water/antifreeze or milky colored oil then it's probably rings.
Posted on Aug 28, 2012
How do I change the oil in a B&S Quantum 5 HP engine mounted on an older Billy Goat Vacuum
horizontal shaft motors mostly have a drain plug in the base of the crankcase ( 1/4 pipe plug either with a square head or hex hole) On vertical shaft engines there may be a drain hole underneath. Another way is to use a oil suction pump to suck the oil out of the filler hole.
Oct 28, 2014 | Cars & Trucks
How do I changes the oil in a briggs & stratton quantum 5 HP engine?
Remove the square plug on the bottom of the engine and the oil should come out. It will make a mess unless there is a extension tube installed. Reinstall the plug and refill in the dipstick hole.
Looking for a bag for the billy goat leaf machine
call billy goat in Lees Summit MO, online search will also help.. since you didn't supply the model # we cant help...
Dec 19, 2013 | Billy Goat Garden
Honda pressure washer GCV160 5.5 HP started smoking while engine was running.
White smoke or black? White means the carburetor is flooding. Black smoke could mean a clogged air filter.
Sep 16, 2013 | Garden
1996 Honda Magna 250 blowing white smoke
Hi, Nirmala1865 your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
White Smoke
smoke out the exhaust CBR Forum Enthusiast forums for Honda CBR Owners
Honda VT250 FII Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT250 FII Owner Manual
Mar 04, 2013 | 1996 Honda V-Twin Magna
I hv activa for 2006 model,my daily travel is almost 50 kms perday - 6days in a week, from last 6 months Activa started giving starting problem and last week white smoke started coming out while drivi
White smoke is classic head gasket problems in water cooled engines ... Your engine is air cooled but you can still have top end troubles. I suggest you have your motorcycle checked by a professional before you ride much more. info on your ride here: http://www.honda2wheelersindia.com/activa/specifications.html
Dec 03, 2012 | 2005 Honda Activa
1999 Honda F6 C Valkyrie white smoke on startup
white smoke is a sign of oil burning; could be a cylinder problem such as worn piston rings; check the spark plugs for signs of oil deposits
Jul 07, 2012 | 1999 Honda F6 C Valkyrie
1984 Honda GL 1200 Aspencade Gold Wing pumping white smoke out the exhaust
Hi, Paul your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
4. WHITE SMOKE on start-up may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 GL 1200 White smoke
overheating GL1200 Information Questions goldwingdocs com
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 1986 Owner Manual
Oct 05, 2011 | 1984 Honda GL 1200 Aspencade Gold Wing
Wife put oil& gas mix in a 4 cycle engine and then it quit & won't restart. What to do to get it restarted?
Replace fuel, (it should run on the mix, won't hurt it.) Pull plug and see if it is wet (fouled) replace or dry off with a small tourch. If it was running ok before should go.
Sep 28, 2010 | Honda Billy Goat Force Blower Leaf Vacuum ...
Having trouble sttaring cold takes many attempts
white smoke points to a head gasket issue, If your coolant is low and smells and looks weird then get the car tested to be sure.
Jan 29, 2010 | 1998 Honda Odyssey
Honda Vertical Engine 6.5 HP OHC 25mm x 3-5/32 GSV190-S3A Logo
22 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
