Question about Ridgid Aquapro 1/3 Hp Submersible Sump Pump Good Pump Needs Float
Aquapro 1/3 Hp Submersible Sump Pump Good getting power but not pumping water out
2 Suggested Answers
  • 185 Answers
SOURCE: I have a SP 300
I would check the input of the pump, exit and the hoses for being plugged up. The shaft of the motor may also not be connected to the pump impeller for some reason. Sometimes the impeller gets clogged with junk. Take the pump out, and clean it out first and see if that solves your problem. you can test it in a 5 gallon pail filled with water.
Posted on Mar 18, 2011
What size power inverter do i need for rs3 1/3 hp submersable pump?
Match inverter rating with voltage and amp draw of motor.
1/3 Hp motor amp draw chart by household voltage:
http://waterheatertimer.org/Color-codewire2.html#motor
Oct 22, 2012 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
We have a submersible sump pump and a check valve in the line and everytime it goes off we get this thumping noise. Could it be a bad check valve?
A check valve is simply a one way flap, or a ball that rolls forward to let water flow in one direction. My guess is if it's making noise, either the pump is not producing an even pressure or the line is not properly secured and is hitting inside a wall. Make sure the line has straps every 3 foot and at any bends.
Feb 19, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have a ace 1/3 hp sump pump it will not come on, what could be the problem
possibly the mechanical mechanisim that is attached to the water level indicator is not switching your pump on properly. could be broken internally or the linkage is set up wrong.
of course there may be other issues like the power source or the motor itself or the thing has siezed up.
Mar 01, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Dec 29, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Oil type
these pumps are supposed to be sealed and not to be able to oil,,
Jun 28, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
My 1/2 HP WaterAce sump (R5S-1) runs but will not shut off
I found a replacement switch which is placed in series with the pump power plug. However when I removed the original switch and plunged the new switch I discovered that the pump motor spins but it does not pump. I installed a new pump.
Thanks!
Jun 19, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Sump pump does not pumped water every time when motor is on
the drive shaft is broke that why it is easy to turn, the pump needs to be replaced
Mar 12, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Ridgid Aquapro 1/3 Hp Submersible Sump Pump Good Pump Needs Float Logo
Top Ridgid Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Ridgid Plumbing Expert? Answer questions, earn points and help others
