Question about Omega Juicers
Omega juicer mbj 390 smoke - Omega Juicers
4 Suggested Answers
SOURCE: how to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Posted on Apr 26, 2008
  • 356 Answers
SOURCE: need to replace latch arm omega juicer...
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
the bottom to separate the base for better access
and view of the situation.
Posted on Feb 09, 2011
  • 57 Answers
SOURCE: my omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
Posted on Sep 03, 2011
Where do i send my omega juicer to for repairs?
Omega Juicers Repair Form
This is a link to the official repair form for all Omega Juicers.
Jul 08, 2015 | Omega Juicers
Why does juicer not start when assembled and plugged in?
It has a 10 year warranty, but check the instructions as there are bound to be safety features on it to stop it working unless properly locked together.
Omega BMJ330 Commercial 350 Watt Stainless Steel Pulp Ejection Juicer...
Review
Omega BMJ330 Review JuicerReviewsDirect com
Manual is here. Doesn't look as if there are any safety interlocks in the drawings. Aha, there is a safety lock! It is good to read to the end :>) Page 23 states;
IF YOUR JUICER ISN'T WORKING
If the latch arm on the right side is not secure and properly in place the juicer's safety switch will not engage. Therefore, the juicer will not work. Assemble the juicer properly.
https://www.omegajuicers.com/media/manuals/EFS_BMJ330_390_Manual_JUNE2014_web.pdf
Aug 22, 2014 | Omega Juicers BMJ330
My omega juicer won"t turn
Sep 03, 2011 | Omega Juicers
My omega 1000 juicer won't turn on - I just bought it today.
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
Apr 23, 2011 | Omega 1000 Juice Extractor
Hello, I just received my omega 8006 and it wont turn on
This juicer has a 15 year warranty which you can contact the manufacturer or retailer you bought it from depending on their return policies and exchange it.
http://www.omegajuicers.com/juicers/masticating-juicers.html
Mar 16, 2011 | Omega Juicers 8006
Need to replace latch arm omega juicer
May 20, 2010 | Omega 1000 Juice Extractor
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
Oct 02, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
Juicers Logo
26 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
