Question about Plumbing
Glacier Bay 900 series pull down faucet,brand new, leaks They sent new cartridge but no instructions on how to get handle off. Help?
  • 297 Answers
SOURCE: American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Posted on Jul 15, 2009
  • 129 Answers
SOURCE: Our glacier bay two handle faucet (sink in half
If you the teapot style faucet directly on top of handle, the little round cap should come off so you can see the screw that lets you remove handle. The other style will have set screws on the outside of either handle. You will need a allen wrench.
Posted on Nov 05, 2009
  • 10865 Answers
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Posted on Mar 18, 2010
  • 94 Answers
SOURCE: I have a Moen Chateau bathroom faucet (chrome,
yes it sound's like you need a cartridge.i think the # is 1225,you might also want to invest in a cartridge puller also,moen make's one, and brass craft make's one as well.
Posted on Apr 29, 2010
  • 349 Answers
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
Posted on May 16, 2010
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
How to fix a Glacier Bay Bathroom Faucet/ Leonardo
Usually they have a small screw, but its hidden under a cap. Look at the handles you should see a small plastic cap sometimes colored red and blue for hot/cold. Using tip of small knife pop out the cap/plug. The screw holding the handle on is in there.
Mar 20, 2015 | Plumbing
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
945 Kitchen Bridge Faucet - Swivel Spout, 9-1/2" (no Han) Brand: Newport Brass NB945-26 Series: 900 The stem moves up and down slightly when I turn on/off the water pressure. It does not leak but...
There is a good chance that if you remove the handle there will be a retainer of some sort. The retainer's job is to keep the stem/cartridge from pushing out due to water pressure. It may be in the form of a nut or a clip. Be careful removing the handle because if the retainer is completely disengaged then the stem/cartridge may shoot up. Turn the hot and cold water off at the valves located under the sink and relieve the pressure by turning the faucet on. If it's a loose nut it will spin freely. Tighten it. If it is a clip you may need to play with the stem/cartridge to align it properly before the clip will move into place..
Jul 15, 2011 | Newport Brass Plumbing
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
May 11, 2010 | Delta & Single Handle Shower Faucet
Mar 18, 2010 | Delta & Single Handle Shower Faucet
Plumbing Logo
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
