Question about Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
Projection light will not come on - Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver
I can't get the projection light to stay on?
I've had this clock for a year now. The projection light will no ...
www.amazon.com/clock-projection-light.../1?_... Amazon.com, Inc.Sep 13, 2013 - The projection light will no longer stay permanently on - it used to. ... if it during the day you can't see the projection because of ambient light. Questions And Answers: does the projection light stay on 24 ...
Jan 7, 2014
Amazon.com: Questions and Answers: Oregon Scientific RM313PNA ...
Jul 19, 2013
More results from www.amazon.com
Oct 19, 2015 | La Crosse Lacrosse WT-5120U-BP Projection...
Tip
Projection Screen Tip #3
In front-projection applications, control of ambient light near the projection screen surface will enhance the contrast and brightness of an image being projected. In order to achieve this, place the screen in an area where ambient lighting is low or controllable.
on Aug 16, 2010 | Office Equipment & Supplies
Tip
Rear projection TV displays a shadow on one corner or side of the screen.
Hi.
This tip may be helpful only if your rear projection TV is displaying a darker shadow on one portion of the screen. If the shadow shape and size will not vary, that means that there is probably a detached mirror in the device called Light Tunnel, located inside your TV.
Most rear projection TV works projecting the light from the internal lamp on the screen. Before reaching the screen , the light will pass through a 'pipe' whose internal surface is covered in rectangular mirrors, located all over the tunnel surface.
A quite common fault is caused by one of the mirror detaching from the the light tunnel internal surface , and falling down or hanging in there. This will be seen on the display as a darker shade located near to one side of the screen.
The light tunnel is located in the light engine. To repair the problem the TV must be disassembled by a technician. Accessing and disassembling the light engine is not a repair that can be done by the owner.
Click here to view pictures of a light engine for a Samsung rear projection model. The tunnel is the optical device located in the light engine.
If you are a technician, to replace the light tunnel you will have to take apart the light engine, that apart of being quite a sensitive optical device, is also the most expensive part on a rear projection TV.
In that case you may find useful the service bulletin posted below, that is illustrating how to replace the light tunnel on a light engine for Samsung rear projection TV. Please be aware, that if you attempt doing this operation without sufficient knowledge and experience, you may damage your TV set beyond repair, as the light engine is very expensive.
How to replace light tunnel on a Samsung rear projection:SERVICE BULLETIN
The file is on PDF format.
Regards.
Ginko.
on Feb 05, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
The lamp light and power light (the red and blue lights) are blinking together but no picture. What can I do
The tv projection lamp has been inside tv about 2 years alredy?Yes.Time to replaced the tv projection lamp.The tv projection lamp life are over.
Jun 15, 2011 | JVC HD-61Z456 Television
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
Tv went of when we watching it i did disconnect it and a red light came on where the power button is does tv have a lamp
Tv "LAMP" LED light indication flashes or light up?Yes,the tv projection lamp life is over.Replaced the tv projection lamp.
Sep 27, 2010 | Samsung HC-P4752W 47" Rear Projection...
My tv wount stay on it goes off after a few seconds
The tv "LAMP" LED light indication flashes or lighting up?The projection lamp has not been change in this tv like a 1 1/2 or 2 years?The projection lamp life is over.replaced the projection lamp.
Sep 17, 2010 | Proscan PS60690 60" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
No picture - green light flicking on and off
Bulb light indicator flashes?Projection bulb use alot,an awile like about 1 or 2.The projection bulb must change it at end of it life cycles.
Apr 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blinking green light
http://www.chrisandnat.com/projects/BlinkingTV/Blink.htm
Sep 02, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Oregon Scientific OR-RM313PA ExactSet Fixed Projection Clock Silver Logo
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
