Question about Dryers
Kitchenaid keys850gq0 dryer - Dryers
Kitchenaid prestige dryer not heating
I worked on a similar dryer with the kenmore brand on halloween. nothing had been done to the dryer since it was new. Take a look:
Kenmore 4-wheel drive dryer de-mystified!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2013 | KitchenAid Dryers
Kitchenaid Dryer Keeps running and clothes remain moist.
Check to make sure you have good airflow to the outside vent. Could have a clogged vent system.
Jul 25, 2012 | KitchenAid Dryers
My kitchenaid electric dryer not heating
Kitchenaid dryers have real weak heating elements, I would test that first, if you have an ohm meter look for small resistance, an open would mean the heating element is bad.
Jun 20, 2012 | KitchenAid Dryers
Kitchenaid dryer model#3401724--Where is reset button for the thermastat on this dryer
There is no reset button on the dryer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Dec 08, 2011 | KitchenAid Dryers
I have a kitchenaid electric dryer. The model
check thermostat first (it have about 5-8 of them inside) check on continues. if this all of them fine, the you have to check heater on continues too.
also if this is electric dryer check if you have 240v in power outlet.
all of this involve some kind of experience with electricity do you should be careful or ask professionals www.appliancesrepairla.com
Jun 24, 2010 | KitchenAid Dryers
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
Replacing moisture sensor in Kitchenaid dryer. I have Kitchen Aid electric superba dryer model KEYS850GT0, ~15 years old. Runs great except the moisture sensor came out into the drum. The part appears to...
Go to www.repairclinic.com and enter KEYS850GT0. With luck you will be presented with a list of common replacement parts and may be able to view a generic KitchenAid dryer disassembly video.
Jul 17, 2017 | KitchenAid Dryers
KitchenAid Dryer won't spin
Probably the motor control switch or thyristor or relay.
Jul 14, 2017 | KitchenAid KEYS750LQ Electric Dryer
I am trying to find out how old my kitchenaid dryer is the model is YKEYE860WW2 Ser:9JH37361
I believe a Kitchenaid with a "J" in the second position of the serial number would have been manufactured in 1999.
Mar 18, 2009 | KitchenAid KAWS850L Dryer
Dryers Logo
14 people viewed this question
Top Dryers Experts
