My Siemens IQ700 displays error code E23. I switched off and on again and still the E23 is displaying. What should I do now? Thanks!
  • 1 more comment
  • Ishai Silencio Aldema
    Ishai Silencio Aldema Jan 14, 2015
    I had the same problem. I solved it. Now here´s what happened:
    Turn the machine off and unplug the machine´s electric plug.I opened the front panel on the bottom of the right side. Unplugged the black hose and let the water inside empty out. Then put it back. Then opened the large plug by turning it to the left til it unscrews totally. NOW: I kind of tilted the machine forward to let the water really get out. Tilt back the machine. Screw back the large plug.
  • Anonymous Apr 02, 2017
    Thanks! Worked perfectly!
You basically have water in the sump at the bottom of the machine, and the sensor gives you E23 error to stop a 'flood'.
Unscrew the back cover and dry it with towels and then a hair dryer and you should be fine...
You must have added extra water and overfilled the tray, or there's a leak somewhere if the problem persists.
Posted on Mar 20, 2014
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Posted on Nov 11, 2008
  • 11 Answers
SOURCE: Error codes
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Posted on Feb 02, 2008
  • 750 Answers
SOURCE: Error Code E23
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 25, 2008
  • 1531 Answers
SOURCE: E23 error code
this is a drain pump relay on the control board either need to replace the wire or the main control board
Posted on May 19, 2010
  • 15935 Answers
SOURCE: indesit washing macine displaying error code F-11
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
I have a problem with my bosch washing machine error code E23 .. it was before this E18 , after cleaning .. the code chanded into E23. What to do ?
Why is it machines always fail at weekends, or public holidays, when there's no-one available to help :-). My Siemens suddenly threw up an E23. Tried all sorts to sort it out but then remembered a similar problem on a friend's machine. An engineer had been called in and looked at the machine the following day. Nothing wrong with it !! This happened twice until someone mentioned how frothy the soap had been whilst washing. That was it.... foam had built up and was confusing the pump sensors. An hour later the foam had dissipated and the machine carried on as normal. So.. I left my Siemens overnight with the drain and filters left open and the following day the machine worked normally. It turns out that one of the cloths in the original wash had been used for car washing - and had traces of foam shampoo in it. Lesson leaned ! It's sometimes the simplest things.....
Oct 10, 2016 | Bosch Washing Machines
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14? > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
P5 variant coding speed 1
I had the same problem. The device (siemens iq700 washing machine) was transferred to siemens service center and the following day I was notified that they were unable to unblock the panel, so it had to be replaced (~200+ euros...) . So this is not a solution, it is bad news instead...
Aug 27, 2013 | Washing Machines
Motherboard msi h61m-e23 (b3)
Try a different monitor, just to remove that from the equation. If that doesn't work then try an add on graphics card. it will save your computer.
Apr 25, 2013 | Micro-Star H61M-E23 B3 - MSI H61M-E23 B3...
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
Error Code E23
E23 means
Or call service!
Dec 24, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
6,902 people viewed this question
Top Washing Machines Experts
