Question about Dell Dimension 4600 PC Desktop
When turning the computer on it says ide configruation and it won't wa Want start up and I cut it off, then it want do nothing, what to do
  • 68 Answers
T sounds like the ribbon cable connecting to one of your devices may be loose. Take the cover off the tower and check all ribbon cables to see if this is the case.
Posted on Oct 18, 2013
Never has enough battery power to start
If the engine is turning over, making a wa-wa-wa sound, then the battery is doing its job and there is another starting problem. If the engine will NOT turn over at all, turn key and no engine movement, then the starter is not working.
Nov 15, 2013 | 1998 GMC Sierra
09 mercedes c350 won't start able to turn ignition switch unable to shift no noise no nothing
I just went through this two days ago. You probably need a new ignition. What happens is these cars lose connection for some reason to the chip in the key and it can't be fixed with just programming. It has to be a whole new ignition. Mercedes are so much different then to any American car. Good luck and it costed around 950 to fix in Wa state.
Jul 22, 2012 | Mercedes-Benz C350 Cars & Trucks
My 2004 would cut off at idle,but start again after a min or so. But time it ran and cut off after a mile. Now it won't start at all. Won't turn over. It will move somewhat when I turned it by
No.
The crank sensor tells the computer when number one cylinder is at top dead center to find the timing for the spark plugs.
If the engine will not crank with the starter, the starter, key switch, battery or cables could be faulty.
Some of these items could also cause it not to start.
If the engine is stuck you won't be able to turn it at all.
Jun 28, 2012 | 2004 Jeep Grand Cherokee
Computer won't boot beyound splash screen
A couple of things to try
a) in the bios reset the settings back to default settings ( usually last tab )
b) Start the pc and press f8 constantly, choose safe mode
c) make sure nothing is plugged in the floppy or usb
This is most likely the way to start the pc
Any other issues then I would start making sure everything is plugged in and the OS is not corrupt
Apr 19, 2012 | Western Digital Caviar Blue 320GB Internal...
I have a dvd Rom sata connected and an ide connected but the ide won't read. i brought a new ide (same brand LG) i plug it in and the pc won't load up. it says insert disk. i plug the old one in...
You need to check that you don't have the same identifier for 2 IDE drives. you can only have one "Master" and one "Slave" on each IDE channel. If you have 2 of one the computer won't know what it is supposed to be doing with the drive.
Apr 18, 2012 | MSI Computers & Internet
My yamaha dt 125 won't start I cleaned the carbs
try your reeds they might be fouled they are vary easy to fix just gotta take your carb off to get to them
Feb 27, 2012 | 2000 Yamaha DT 125 R
Cannot start up mcafee to scan my computer it will not open for whatever reason?
click on start -run -msconfig---
select diagonistic mode ---
click on start up tab ----
checked check box with mcafee -----
then click on sevices tab --checked all the check box with mcafee ----click on apply --ok --restart ------
--once windows started --put check mark on do not show this msg again ---on system configruation windows---click on mcafee --it will work fine
for any calrification contact
chinmay_c_pandey@yahoo.co.in
Nov 05, 2008 | Computers & Internet
Computer does nothing.
if when you remove the ide then it boots means the ide has been crupted or fried.
Jan 16, 2008 | Biostar M6TSU Motherboard
Dell Dimension 4600 PC Desktop Logo
19 people viewed this question
Alun Cox
