Question about Nikon Optistation 7 Microscope Lamp Illuminator Lhs-h100p-1 Working
I'm looking for the two parts of Nikon optistation3 P/N 4B996-088 B/D Sight Change unit lamp housing for LHS-H100P-1 12v100W
I have a savage 110 270 win.i put a nikon buckmasters2 4x12x40 on it im trying to sight in at 50 yards i looked it up it says to sight in at 50 yards it says -0.14 i do not know what that means
The only way to sight in is to bore sight or use a bore sight laser
then put rounds down range at the target to get the point of aim and point of impact to converge
Dec 03, 2016 | Nikon Optics
Will Xenon Series H10 12V 45W Halogen Bulbs work for my 1995 Chrysler LHS
You install only a lamp with the correct number
stamped on it for your vehicle
No owners manual,have to look them up at parts
store
What brand,model & all your asking I have no idea
Just correct lamp #
If you want some different new fangled brand make sure
it is compatible
Mar 28, 2013 | 1995 Chrysler LHS
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
In a 94' Chrysler LHS what is the firing order? Took the plug wires off the housing unit.
1994 Chrysler LHS
3.5 liter SOHC V-6 VIN "F"56539136.gifI HOPE THIS IS WHAT YOU NEED. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED. FEEL FREE TO COMMENT ON THE ASSISTANCE
Sep 06, 2009 | 1994 Chrysler LHS
My 1997 LHS overheats I change out the thermostst.
if you dont physically see or smell any antifreeze your more than likely experiencing water pump failure, if not that you may have heater core issues, check the interior on the passenger side closest to the front console floor if its wet you have a heater core issue if not have your cooling system pressure checked for anything else.
Jul 12, 2009 | 2000 Chrysler LHS
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Change brake light 2000 lhs
    The rear lenses can be removed by opening the trunk, remove the possible liner that covers the hex nuts on on the lamp housing behind the lens assembly and remove them, remove electrical connector and replace bulb.
    Mar 16, 2009 | 2000 Chrysler LHS
    How do you replace the headlight bulb on a 2001 chrysler lhs.
    This can be done buy popping the hood and removing the bulb from the rear of the headlight housing. don't screw with the housing because, its leveled for optimal sight range.
    Jan 28, 2009 | 2000 Chrysler LHS
    Xl-2100u
  • Unplug your Projector from your power outlet
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    HOW TO REPLACE HEADLIGHTS ON 2000 CHRYSLER LHS
    ATTN: NIKKICARROLL
    here is how to replace the bulb in your vehicle
    1. Release the hood latch and open the hood.
    2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp.
    3. Remove the screws holding the headlamp module halves together.
    4. Separate the module halves.
    5. Disengage the wiring from the headlamp bulb.
    6. Remove the retaining ring from the back of the headlamp bulb.
    7. Pull the bulb from the lamp.
    To install:
    1. Push the bulb into the lamp.
    2. Install the retaining ring to hold the bulb in the lamp.
    3. Engage the wire connector to the back of the headlamp bulb.
    4. Place the module into position on the vehicle.
    5. Install the screws to hold the module to the vehicle.
    6. Install the radiator closure panel sight shield.
    7. Check the headlamp alignment and operation.
    88176gb1.gif Exploded view of the fog lamp with the bulb removed
    Click to Enlarge
    2. Remove the radiator closure panel sight shield as needed to gain access to the headlamps.
    4. Separate the halves.
    5. Remove the fog lamp wire connector cover.
    6. Disconnect the wires from the fog lamp bulb.
    7. Disengage the retainer clip holding the bulb to the fog lamp.
    8. Remove the bulb from the fog lamp.
    To install:
    1. Place the bulb into position in the fog lamp.
    2. Engage the retainer clip to hold the bulb to the fog lamp assembly.
    3. Attach the wire connectors to the fog lamp bulb.
    4. Install the fog lamp wires connector cover.
    5. Place the module halves together.
    6. Install the screws to hold the headlamp module halves together.
    7. Install the radiator closure panel sight shield.
    8. Verify the fog lamp operation and alignment
    ATTN: WDSNEED1
    Removal & Installation 88176g87.gif Remove the screws retaining the headlamp module to the mount adapter
    Click to Enlarge
    2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp fasteners.
    3. Remove the screws holding the headlamp module to the mount adapter.
    4. Separate the headlamp module from the mount adapter.
    5. Disengage the wiring from the headlamp and foglamp.
    6. Remove the headlamp from the vehicle.
    To install:
    1. Attach the wires to the headlamp and foglamp assembly.
    2. Place the headlamp module into position on the mount adapter.
    3. Install the screws to hold the headlamp module to the mount adapter.
    4. Install the radiator closure panel sight shield.
    5. Check the headlamp alignment and operation.
    Jul 28, 2008 | 1994 Chrysler New Yorker
    Nikon Optistation 7 Microscope Lamp Illuminator Lhs-h100p-1 Working Logo
    Top Nikon Science & Laboratory Experts
    matt
    matt
    William McMath
    Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
