Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Error code e00064 0000 ir ir3300 - Canon imageRUNNER 3300 All-In-One Laser Printer
4 Suggested Answers
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
Cogz
  • 1326 Answers
SOURCE: error code 0001900 for ir3300
The error code means the waste toner bottle is full. It may not be full, but once the waste toner bottle neck is dirty and the copier thinks it is full. It's a poor design from Canon. The waste toner is on the left rear side of the copier. It is behind a panel with one screw that holds it in. Remove the cover and remove the waste toner bottle and carefilly empity out the waste toner into a plastic bag. Make sure you clean the neck of the bottle. There are 2 windows on the neck. That is where it gets dirty. Return the bottle back into the copier & return the cover, Then turn the main power switch on the right side and turn it back ON and thats it... Good Luck
Posted on May 02, 2010
  • 89 Answers
SOURCE: canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
Posted on May 24, 2010
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
Canon ir3300 error code E000019-0000, hOW CAN I SOLVE IT ???
Sir
Pl. do the waste box cleaned-check the waste sensor-the harness.
Dec 21, 2014 | Canon IR 3300 Digital Copier
How do I correct problem E261-0000 in ir 2420?
The error code is to do with the power supply, here's a brief flow chart to help you. Canon iR3300 Error Codes
Oct 11, 2014 | Office Equipment & Supplies
What is the reason for blank copy in ir3300 copier
Check the fixin unit,lamps,thermistor,thermal fuse
Aug 02, 2014 | Canon IR 3300 Digital Copier
I need error codes for canon ir 3300
Hello, Here is a link to the full list of all the Canon iR3300 error codes with full details.
http://www.printcopy.info/index.php?l=en&mod=free&chap=erc&brand=Canon&model=iR3300
May 20, 2011 | Computers & Internet
How to clear E00002-0000 problem in ir3300 model
How to Clear IR 3300 Error Code E00002 -0000 problem
Jun 09, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
old marine
old marine
