Copiers
Problem for Copiers
Generic problem for all Copiers
Cannot copy Double-sided
By mattcomstock on Sep 26, 2007
I seem to be having trouble copying double sided documents, I have followed the instructions in the manual to make sure the machine is in copy mode and to press the "duplex/split page" button. Then I get the sub-menu of "2-Sided Copy" and "Page Separation" and then I am to press "enter" on "2-Sided Copy" but when I try to do this a message comes up stating "cannot be combined" and I have no idea how to fix this problem. There is nothing in the manual to help me try and troubleshoot this problem so if you could please help me out it would greatly appreciated.
Comments:
Sep 27, 2007
- Kyocera Mita 2030, and I am using the top feeder
Same Problem
Jan 04, 2009
-   I have no idea how to copy double sided on my damn copier? its driving me crazy!! -   Guest
Feb 22, 2008
-   same problem-   Guest
Best Solution
posted on Sep 27, 2007
Helpful)
MediaMan85
Rank: Guru
Rating: 86%, 147 votes
Q1- What make and model of copier are you using?
Q2- Which document feeder are you using?
Comments:
Sep 27, 2007
- On this model the duplex unit and duplex feeder (allows automatic 2 sided copying) are both optional. I am not sure which you have.
If you don't have many to do you can always do one side and use the bypass paper feeder to do the second. This can work for small amounts but is not recommended for larger volumes.
Was this helpful?
Yes
No
Solution #2
posted on Oct 18, 2009
Not Rated)
gilbertgonz8
Rank: Guru  Office Equipment  Expert
Rating: 93%, 30 votes
Can you please tell me what kind of machine you have? Brand and model number?
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
how to trun on a xerox copier
Answer
HP c4280 Photsmart paper feed causing jam. Pulling on right side.
Answer
We have the Oce im2330 for our small business. It was working fine until a couple weeks ago when I... (More)
Answer
I am in the middle of a print job when suddenly the copier shows a message to call for service. The... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
