Lg Manual GR-D907SL
Fridge
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
  • 47 Answers
SOURCE: I have a LG GR-L207DUZA ''er ff''
i dont have the manual however.. this could be your freezer fan is perhaps seized.. you can test this by leaving your freezer door open to raise the temp and wait ti see if your fan comes on.. this may take upto 10 minutes so be patient
Posted on Nov 11, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
reyjoshua07
  • 1157 Answers
SOURCE: LG side by side fridge
Hi henning287,
The leaking water is often caused by the drain pan. There are some ways on how to correct this issue, either you clean the pan and reposition the tray. In addition, here are some tips that you can apply to solve this problem. Please follow the steps below.
Before conducting any repair, please remember your safety. Unplug the machine or shut off the power at the breaker panel to avoid any electric shock.
1. Remove the drain pan and clean it with a warm soapy water or water and baking soda.
--> the drain pan is located at the bottom of the refrigerator behind the front grill.
--> Please remove the grill which snaps into place. Hold the drain pan while pulling slightly upward and forward.
2. If you noticed that the pan is too closed to the compressor please reposition the tray.
3. You may also try to check water invelt valve. It is located behind the refrigerator. Look for a water supply line coming into the valve and turn it off at the source. Now disconnect the supply line. It has screws so you need to remove them.
4. The water inlet valve is connected by two wires. Before disconnecting the wires please label the wire placement on the water inlet valve.
5. The wires are connected to the terminal with slip on connectors. Firmly pull the connectors off of the terminals ( don't pull on the wire ). You can use a pair of needle-nose pliers to remove the connectors. Please check if the connectors and terminals has corrosion. If corroded they should be replaced.
If has water inside the refrigerator, you need to clear the drain tube.
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Hope it helps.
Thank you for using FixYa.
Posted on May 17, 2011
Lg fridge GR-B3993LQ is not cooling
Make sure that the thermostat is working and that the compressor and associated fans are working (getting Power).
If both units are working and still no cooling your evaporator could be frozen because the defrost timer/element is not working. Worst case scenario is that you may have developed a small leak and lost refrigerant.
Mar 11, 2015 | LG Refrigerators
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
''H'' error code on front panel of a GR-559FWD - Fridge not working but Freezer compnent oK
your manual or instructions are located behind the kick plate or on top or your fridge underneath the hinge caps. or visit manualsonline.com
Jul 01, 2010 | LG Refrigerators
Nov 11, 2009 | LG Refrigerators
Mar 02, 2009 | LG LFD25860
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
