Question about Refrigerators
Kitchenaid kfcs22evms3 drain plugged
Fridge leaks from freezer
Sounds as drain is plugged. Remove rear cover in the freezer and check drain . Also clean drain pipe in the fridge at the top part and clear drain tube
Aug 26, 2014 | KitchenAid Kitchen Aid 19.8 Cu. Ft....
Upper drawer dishwasher won't drain
First =check for a plugged drain line
Second = check for plugged screens in the unit.
It could also be your pump. The vanes are only plastic and they sometimes just give out.
Jan 07, 2014 | KitchenAid Kitchen-Aid KUDD03DTSS...
My kitchenaid dishwasher will not drain.
Check to see if strainer in the bottom of the tub is plugged first.If thats not it, it could be the discharge hose plugged or the pump, as long as it is completeing the full cycle.
Nov 26, 2011 | KitchenAid Dishwashers
KitchenAid Dishwasher won't drain KUDI01ILBL6
Do you have an air gap on your sink? Check it to see if its plugged.
Nov 15, 2011 | KitchenAid Dishwashers
Kitchenaid Styledmaster # 622784, The washer is leaking over the floor. All of the exterior hose connections seem to be OK.
Note : Make sure the water on the floor isn't the result ofa plugged floor drain. It happens!
Unplug the machine beforeperforming any repairs.
Thank for using fixya.
Jul 28, 2011 | KitchenAid Washing Machines
Build-up of soft ice all over in the freezer
Do a manual defrost of the unit. Unplug it.. empty the freezer and place a fan b l o w i n g into the freezer for about 2 hours.
After the manual defrost return the unit to normal service.
If the soft build up of ice shows up again take a very hard look at the door seals. Look for tears.. gaps or any place the gasket is no longer attached to door face
This unit should defrost about every 10 hours. If it does not automatically defrost,,,, doing a manual defrost will only keep the unit going if you repeat the manual defrosting drill every 2 - 3 days.
If it just never goes into the automatic defrost cycle at all, the control board could have failed. PN: W10116216
Item 5 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KFCS22EVMS3/0593/0161000/W1003150/00003?blt=06&prst=&shdMod=
A failed defrost heating element can also cause this. Item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-number/Kitchenaid-Parts/Refrigerator-Parts/12729129/0046/106/Model-KFCS22EVMS3/0593/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=KFCS22EVMS3&subCompDesc=Unit%20parts&brandDesc=KITCHENAID&modelDesc=REFRIGERATOR&pathTaken=partSearch&blt=11
Nov 18, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid dishwasher won't drain someone opened door during cycle will this cause a problem
Opening the door wont matter. If you stop the cycle during a run it will always go into a drain. You might have a plugged drain line or burnt drain pump..
Apr 04, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Kitchenaid superba disposal
IF THE WATER IS NOT IN THE BASIN OF THE DISPOSAL, THE PLUMBING IS THE PROBLEM, NOT THE DISPOSAL.
YOU CAN TRY TO TAKE THE TRAP LOOSE AND SEE IF THERE IS ANYTHING STUCK IN IT OR YOU COULD TRY SOME DRANO IN THE SINK WITH THE WATER STANDING IN IT. THE TRAP IS THE PART OF THE DRAIN THAT RAISES UPWARD TO HOLD WATER. IT KEEPS THE SEWER GASSES FROM COMING UP THROUGH, BUT IT ALSO IS A GOOD CATCH ALL FOR HEAVY ITEMS AND GREASE.
LOOSEN THE NUT LOCATED AT EACH END OF THE TRAP. HAVE A BUCKET UNDER IT TO CATCH ANY WATER THAT DRAINS OUT. REMOVE THE TRAP AND SEE IF THERE IS AN OBSTRUCTION IN IT.PRESSURIZED AIR WILL SOMETIMES CLEAR AN OBSTRUCTION IN A DRAIN LINE ALSO,
Jan 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
