Question about Freezers
Freezer The freezer of my freezer/fridge combo is no longer cooling and I hear a ticking sound every 30 minutes. Help?
  • murugas20032 Jan 24, 2009
    our 5 years old single door kelvinator makes noise and the cooling is in low level.
  • 447 Answers
Very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
Fridge not cooling
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I can only advise in general terms.
The basic operation of a combo freezer/fresh food section unit are the same.
Generally, the fresh food section does not have a independent cooling source. It gets its cooling from the freezer section. There is a air damper from the freezer to the fresh food section. This air damper is controlled by a thermostat. I suspect that either the thermostat is bad or the damper. Your air damper is wide open.
Feb 15, 2015 | Daewoo FRSU20IA Freezer
We have a Bosh KIM29473GB for some time water has been collecting in the bottom tray of the fridge and only takes a few days to fill up, this weekend the freezer stopped working and now nothing works.
If you hear a click every few minutes and a buzz / click then nothing, it would sound as if your compressor is gone, the water problem is the defrost drain pipe is blocked
Oct 06, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge noise cutting out
To be honest it sounds to me like your fridge may be ok?
To extract the heat from within the fridge interior a compressor (motorised pump) moves gas around a series of pipes around the cabinets insides. This movement of gas causes heat to be picked up and taken away externally to the outside world. When the fridge temperature reaches a predetermined level (around 5C) the compressor shuts down and all is quite. The sound of running water you hear is the coolant gas changing state from gas to liquid and running through the coolant pipes. If the fridge is doing it's job and keeping the content cool then I wouldn't worry. One of the reasons you are probably noticing this sound is because it is a table top fridge. Built in fridges make the same noises but you don't really hear them so much because of the cupboards screening the sound.
Dec 27, 2013 | Igloo Cooler IGLOO Freezer. 3.6 cu. ft....
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
May 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Fridge freezer not cooling
buy a new freezer and never go near it with a screwdriver try unplugging it to remove ice
Mar 12, 2009 | Freezers
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Fridge Freezer in Autodefrost mode
Power surge can cause problems such as you have. I am not familiar with your brand but it sounds like the defrost timing circuit is your problem. Defrosting the surface of the back wall is not the answer. The cooling coil in the freezer is behind the back wall normally and a surface defrost does not do the trick of defrosting the coil. Have an appliance service tech check it out for you.
May 30, 2008 | Freezers
Freezers Logo
259 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
