Question about Whirlpool Refrigerators
Fan no power n387 fridge freezer - Whirlpool Refrigerators
HOW DO I FIX
I see nothing about checking freon level .
Nov 24, 2015 | Refrigerators
Whirlpool fridge n387
Please check your thermostat.
Jul 29, 2013 | Refrigerators
Small fridge no fan /freezer works but fridge doent cool
Unless the fan works there will not be any flow to the fridge section as the cooling comes from the freezer coils. check the fan and replace after checking the power to the fan.
Jan 30, 2013 | Kenmore Refridgerator Air Flow Diffuser...
The freezer works the frig doesnt get cold but its not warm just mild
open the freezer and at the back is a fan with a cover check the fan operation and housing if fan iced over or ice or debris blocking [food bag ]clear and check operation if fan doesnt work at all check power if power good replace fan if fan good check in fridge side for operation of flapper where air from freezer enters may be stuck or blocked air from freezer controls ur fridge side --if freezer side works than one of above problems which are the most common should get u back on line
Jan 19, 2011 | Admiral Refrigerators
My refrigerator stopped cooling.But my frezzer still works.
check the fan that runs between the freezer and fridge section [usual access is from the freezer side] if fan not working check thermostat is set at coldest in fridge then check for power to fan if power check for blockage from ice, food.etc if clear check damper inside housing is open and working properly---the fridge is cooled down from the freezer via the fan
Jul 26, 2010 | Frigidaire Refrigerators
Simpson fridge stopped working. The freezer still goes but not the fridge part. At the time the power fuse box overloaded (around the same time as the fridge died). Not sure if that was connected but power...
If this is a standard upright fridge (freezer at top), then the usual principle applies: cold air drops.
A small fan (situated between freezer & fridge) should be functioning, which forces cold air from the freezer, down into the refridgerator.
I would recommend you first determine if this small fan is operating (this is the noise you would normally hear, when you open the freezer door) and if not, then replace the fan.
If fan is working, then I would suspect a faulty thermister which would require a technician.
With repairs of older devices, it's always best to obtain quotes first, as often the cost of repair could well amount to up to 40% of the price of a new one.
Good luck...
Feb 14, 2010 | Refrigerators
Any info on electrolux RA1300 gas fridge. Freezer works well but fridge compartment doesn't chill
If you had an electric fridge the problem is usually the evaporator fan motor ($30).
I suspect that you may have the same problem. Generally, freezers are cooled only, when the fridge needs cooling, the evaporator fan comes on and blows cold air from the freezer to the fridge compartment. The advice below is for an electric fridge but may also work for you, it's worth a try I suppose.
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge, or disconnect gas etc. Fan should be located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Electronics - Others
Fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Jan 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer fan
actually, freezer fan has to come on otherwise how is the fridge supposed to cool.(fridge draws off from the freezer compartment). check if there is power to the fan. if freezer is nice and cold and fan does not run(assuming there is no power to the fan at that time, then you would need to check your freezer thermistors after that, your board. all this is assuming you dont have a blockage or shortage of gas in the sustem.
Sep 20, 2007 | Kenmore 72293 - Stainless Steel Top...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
