Question about Cameras
Case Ih Problems - Cameras
Year of tractor by serial number
CaseIH Farmall 45
2008-2011
Provide the serial number to your local Case IH dealer for assistance with the date:
Case IH Dealer Locator Search Find Dealer Near You Case IH
Jun 04, 2017 | Toys
I am looking for the year a case ih 1020 header was made serial number cb j033178
perhaps a case IH dealer could assist you with this . not many farmers come on to answer questions
Nov 23, 2015 | A&I Products A-598171R1, Case-IH, Reel...
I need a wiring schematic for a case ih 4230
Official Case IH Online Parts Store and Case IH Catalog for Best Parts...
This will get you to the online manual with tabs to choose from, when you pick it shows blown up schematics.
May 05, 2015 | Garden
C-3B02 in bizhub c452
This going to get expensive, could be any of the following the IH coil unit or IH Power supply unit. This series of machine uses a magnetic field to produce heat for the fusing process the process of fusing the toner to the paper, any way the code you have is stating the IH pwr sup or coil unit are not talking to the copier cpu. It could also be a relay board between the cpu fuser system, worse case the image control board. I would go with fuser power supply. Just my humble opinion.
Jan 30, 2015 | Konica Minolta Bizhub C452 Copier
IH 300 point gap
Well I asked around and found about 0.020 or in better terms of understanding is about 20 thousand's of a inch.
Apr 20, 2014 | The Times Case Corporation Tractors...
Case IH tractor stops when the battery is flat
charging system is not working
Feb 16, 2014 | Garden
Ih tractor
You will need to bleed air from the injector pump it self. Next to test glo plugs pull from engine and connect a wire to the body to the earth. Turn on ignition and press button for a few seconds and they should glow. If not check for power to the plug
May 06, 2013 | The Times Case Corporation Tractors...
I have a Case IH 5230 Maxxum tractor with shuttle hesitation.
I have a 1974 case backhoe 580 it will not move in any gear.
Jul 10, 2009 | Milwaukee Tool Case Heat Gun
Cameras Logo
481 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
