Question about Radio Communications
Yaesu ft 8800 r/e will not turn on - Radio Communications
5 Suggested Answers
  • 95 Answers
SOURCE: INTERCHANGE MODULE
I'm gonna go out on a limb here and assume you are talking about the band modules, right? If so it will accept some in the 6m,2m,and a couple of the 70cm bands. The model numbers I know it will accept are as follows: FEX-767-2,-6,-70A and -70B. If your module is one of these they are interchangeable. BTW, all of these modules are presently discontinued I'm sorry to say. Hope this helps!
Posted on Mar 28, 2009
SOURCE: Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Posted on Apr 07, 2009
  • 211 Answers
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
Posted on Jan 30, 2010
  • 4 Answers
SOURCE: Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Posted on Mar 17, 2010
YAESU FT 8800 WILL POWER UP AFTER USING CHIRP PROGRAMING
it sounds like you loaded corrupt data into the memory registers or god forbid, let the magic smoke out of the CPU, and we all know with out the magic smoke it wont work anymore. disconnect the programming cable plug the mic back in and pull out the owners manual and look up how to do a factory reset, and perform one EXACTLY as instructed. if this doesn't fix the issue the radio is going to need service. You don't mention if you used a factory cable or after market programming cable. Ive never used Chirp software, so I cant comment on it, in fact, Ive never heard of it before and I run Yaesu equipment in my mobiles and for my handhelds.
Sep 28, 2014 | Yaesu FT-8800R VHF/UHF Dual Band Mobile...
Software Menu Aligment yaesu FT-857
http://www.hampedia.net/yaesu/ft-857-second-menu.php this link lists the settings to put back to factory abc together when switching on to access
Apr 10, 2013 | Yaesu FT-857D HF/VHF/UHF Mobile...
External mic for ft 50 yaesu purchase
Yaesu offers the MH-34B4B Speaker Mic or the MH-37A4B Earphone Mic for the FT50 HT.
Speaker Mic (Heavy / Standard Duty)
Earphone Mic (Light Duty)
Any ham radio store should be able to obtain these - if they are still in production / stock by Yaesu. Ham Radio Outlet aka "HRO" has stores nationwide and can ship direct.
I hope this helps!
Jan 26, 2012 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FT-100D transmit problem
has it been opened up to talk on
Dec 17, 2009 | Radio Communications
Service manual/parts list for yaesu ft41r or ft11r
You should be able to get the keypad from Yaesu parts: \
(714)827-7600
You may be able to download the manuals at: www.mods.dk
Sep 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
Jul 14, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
OPERATORS MANUAL REQUIRED VIA FREE DOWNLOAD
dadoftoffee, hi. I found a manual listed but not sure what you mean by a euro version. Check this out and see if it's something you can use.
http://dw.ham.dmz.ro:8080/downloads/yaesu/ham.dmz.ro.ft-8800r.pdf
There's some mods and other info on the scanner here;
http://www.ham.dmz.ro/yaesu/ft-8800r.php
A little more technical info available here.
http://www.stevelarkins.freeuk.com/ft8800r_servicing.htm
I hope this helps you out in your search,, let us know. Mechanic
Feb 28, 2008 | Radio Communications
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
