Question about Cosco Juvenile Cosco Sway n Play Swing Zambia
How do i change the batteries in the sway and play
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I CHANGE THE BATTERIES AND WHAT SIZE ARE THEY?
tools needed : 1 Phillips head screw driver, 4 d cell batteries.
as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.
it's the leg with the on off switch.
insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door.
unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.
hope this helps!
Aug 02, 2013 | Cosco Juvenile Cosco Sway n Play Swing...
2004 Camry sways in rear end area
Is the UPPER part of the Sway bar connected to the Chassis
Apr 10, 2013 | 2004 Toyota Camry
Need to know how to change the steering gear box on a 2001 neon
There are adjusting screws on boxes that will take out excessive play in the steering. However if it still follows the road contours dips etc I suspect that the alignment has not been done to specs as incorrect t castor and camber will affect the handling. Also the problem may not be in the front but in worn suspension bushes and rear alignment
Apr 07, 2013 | Dodge Neon Cars & Trucks
I have a 2000 Chrysler Concorde. Good Car. 145000 miles. Changes the struts last year and this year changes the bushings in the front wheel drive. The car is making a popping noise in the front end and...
could be cv joint but jack up wheels and move tire up down and left right up down if play check ball joints /anti-sway bar bushings--------if play left to right than check idler arms and steering system /and anti sway bar bushings
Dec 07, 2012 | 2000 Chrysler Concorde
I jusr replace outer tie rod ends and had a front end alignment, had all the tireschecked and rotated, i have a a slight play in the steering wheel , My question is could it be sway bar links or bushings
The sway bar has little to do with steering, it stabilizes the chassis. The play in the steering could be in the rack & pinion assembly. The shop that did the alignment should be able to check that out.
Aug 20, 2010 | 2004 GMC Envoy
How to change 1998 Plymouth grand Voyager front sway bars
unbolt the sway bar links from the control arms and the two brackets holding it to the frame. make sure if you jack it up jack up the front end. if you jack up one side and not the other and take the sway bar loose it will be loaded and could cause injury if not careful as long as both front tires are off the ground the sway bar will not be loaded and will be safe to deal with
Oct 19, 2009 | 1998 Plymouth Grand Voyager
93 caprice
besides changing the bushings, did you check the sway bar itself or the degree of the linkage bolts, in time seeing as it's 16 years old now it may have been stressed and bent, buying smaller linkage bolts with stiffer bushings may help tremendously...worst case scenerio you may have to replace the sway bar itself.
Dec 04, 2008 | 1996 Chevrolet Caprice Classic
Cosco Juvenile Cosco Sway n Play Swing Zambia Logo
57 people viewed this question
Top Cosco Juvenile Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Cosco Juvenile Baby Gear Expert? Answer questions, earn points and help others
