Question about i-mate JAM Pocket PC
Imate pocket pc
My imate pocket pc 2003 is not getting charged when it connected via a ac adapter what is the problem
  • 146 Answers
Try with data cable by connecting it to your pc,, if it does,, i m afraid adapter is faulty.
Posted on Jan 25, 2008
SOURCE:
I wanna connect my imate jama to my computer but the problem is like this when i am connect my imate with my computer the message is generic rndis how i can solve this
Microsoft ActiveSync 4.5 free download. ... Requirements: Windows 2000/ XP /2003/ XP64 License: Freeware Synchronize your Windows ... Microsoft ® Outlook® 2000 is not supported
Jan 23, 2011 | i-mate JAM Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My Dear, Assalam-o-Alaikum. I am trying to connect the imate to PC for accessing internet on my laptop through i mate, Please advice.
hi thanks for using fixya!!
First, you need to download and install to your laptop the Activesync, please click HERE to download and install it. After the installation, connect your Imate to your laptop via USB cable. Follow then the next instructions in regard the synchronization.
Now, you can access internet to your Imate when you are connected to your laptop.
If you need further assistance, let me know!
Please do rate my solution positively! thanks!
Jun 08, 2009 | i-mate PDAL Pocket PC
Imate jaq having problem to connect the pc
I have problem to conect with my PC with imate jaq so p/l let me know at [email protected]
Sep 07, 2008 | i-mate JAQ Pocket PC
Internet connetion to my desktop via imate
hi ! firned i have I Mate too
but i dont have PC suit and i have a problem with net conection too
please tell me how to access my imate with pc and internet
Jul 03, 2008 | i-mate PDAL Pocket PC
Drivers for imate jam
http://www.ziddu.com/download/3568715/Imatepcsuitactivesync4.zip.html
here is the software for your imate pocket pc.
if you want more softwares or any other things please send me your e-mail. I'll send you More Links.
my e-mail : [email protected]
May 25, 2008 | i-mate JAM Pocket PC
Lost of drivers of imate jamin
i lost my pc suite for my mate,how can  get it
Apr 14, 2008 | i-mate JAM Pocket PC
AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Sep 12, 2005 | HP Jornada 548 Pocket PC
AC charging issue
Sounds like a defective AC adapter.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
i-mate JAM Pocket PC Logo
43 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
