Question about Xantrex Technology Electronics - Others
Xantrax xw6048 with 30 each 235w orion poly solar panels.company rep. stresses that it should be connected no more than 3 sets each.What does this mean?I was thinking of 3 strings of 10 panels.
    Scholar:
  • 95 Answers
Yes. That's what that means. 3 strings of series wired panels. Now, the panels are going to be around 30 volts (vmp), so it all depends on the input voltage of that unit. I'd check the voltage range of the charge controller. If it's limited to lets say, 192 volts max for a 48 volt system, you can do 3 strings of 6 panels to keep it under the voltage.This will give you a 4230W panel output every hour, which is substantial.
Posted on Oct 18, 2013
Tip
Which solar panels can be used with Imeon?
Because Imeon inverter is transformerless, only two types of PV modules are acceptable: mono crystalline and poly crystalline. Do not connect any PV modules that may introduce leakage current to the inverter (such as non-grounded PV modules). Refer to technical datasheet of the PV modules.
NOTE : The PV DC voltage and current must be within the MPP range of the MPPT Input. Refer to product documentation
imeon energy -solar-hybrid-inverter-imeon3.6-45-°angle-view--wigaoetmofgu4i3phjlbvsds-5-0.png
self consumption autonomous house inverters solar batteries Imeon Energy
on Mar 12, 2018 | Inverter Electronics - Others
I need to know what kind of inverter I need for a solar system consisting of four 305w solar panel, connected in cerise.
With so few panels, you could use microinverters in parallel instead of series, such as from Enphase
https://enphase.com/en-us/products-and-services/microinverters/family
But if you want to stick with series, then a 1.2 kw string inverter is what to look for. Perhaps something like these
http://www.micromaxenergy.com/pdf/String-Inverter%20(2).pdf
Sep 20, 2015 | Suntech 305W PV module STP305-24-Ve poly
Windows 7 driver for orion SLED2468W
Settings usually with a good USB cable, the settings on your TV when doing input go to USB where pictures and cable will show and connect from your computer to the back of TV and if doesn't work call TV company they always know the hook to this.
Aug 13, 2015 | Orion 24" Class LED-LCD 720p 60Hz HDTV,...
What kind of solar panel would i need to power a grundorf jp 5
It depends on many factors. What is your geographical location, in very hot climate generally poly panels do a little better and you need to match your charge controllers input with the solar panels. sometimes for small systems big panels with higher current ratings do not do well.
Apr 03, 2014 | Solar Electronics - Others
Using solar panel to power small appliance
If you guys want a free way to get your electric and natural gas supply for free in PA,NJ,CT,NH,ME,RI,NY,MD,OH,ILGA.,Texas .Get you Energy company to pay you every month too. Call me : leave a message I will get back to you ASAP .i will be happy to help .People helping people .Scott at 267-549-3746.
Mar 31, 2014 | harbor freight tools THUNDERBOLT MAGNUM...
How many major companies have solar panels?
click in this link
http://en.wikipedia.org/wiki/List_of_photovoltaics_companies
scroll down on page to see manufacturers.
Hope this helps.
Dec 03, 2012 | Computers & Internet
We have set up the solar power fountain with pump as per instructions. The pump is submerged, solar cell in full sun for 3 days, but the pump does nothing. doesn't even make a sound. Its an 8 watt...
Using a battery/volt meter, check if the battery has a full charge. Also check if there is an on/off switch on the back of the solar panel. If the batteries are removable and are standard batteries, charge them using an AC battery charger the first time. If not, you may have a defective solar panel and should return it to the store/manufacturer.
Aug 20, 2011 | Solar Powered Pond Fountain Pump Kit - 80...
Solar power cell
Here is a link to a site for solar panels and all the required information you need for your application:
http://www.firemountainsolar.com/
Here is their phone number also: 1-877-230-7710
Just give them a toll free call and their friendly staff will set you up with the equipment you need for your project. This is where I bought the solar system for my RV. They are the best source for solar sells and info on the internet. I researched 20 companies before I went with Fire Mountain Solar. I was fully satisfied with every aspect when dealing with this company and they stand behind their work and their products. You can not go wrong with them.
I hope you find this information priceless. If you do please take the time to rate my solution fixya as I found you the best source for your solar cells from the best company that I deal with myself. If you need any help in the future I will help you for free again. I do this for a hobbie. geokohler@gmail.com
Jul 22, 2008 | Heating & Cooling
Solar battery charger
Yes, but the efficiency of solar cells is terrible. Its one thing to use free sunlught to charge the cells, its another to have to pay the electric company to do it. If you can access the batteries in the solar rig easily and they are in the correct voltage range, I think you would be better off getting a battery tender (trickle charger). Just let the van sit outside until the batteries are fully charged, then connect the battery tender to keep it fully charged.
Jun 04, 2008 | 1992 Dodge Ram 250
Electronics - Others Logo
51 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
