Question about Exercise & Fitness
How to tighten the belting - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
See the video attached. God bless you
Posted on Oct 18, 2013
Belt won't tighten on 98 dodge caravan. Does the
If the alternator is fixed then its the tension pulley that tightens the belt. but if the alternator is mounted with a pivotal pin and can be moved along a bolt slot, then it's the alternator that tightens the belt.
Oct 28, 2012 | Cars & Trucks
Tip
When the walking belt is slipping during use.
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
on May 01, 2010 | Exercise & Fitness
My walking belt is off cener
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
May 07, 2010 | Proform 530 Treadmill Walking Belt
Treadmill belt keeps slidding to the side
Apr 08, 2010 | RTO Image 15.0R Treadmill Walking Belt
Belt is slipping
Apr 03, 2010 | Cadence Exercise & Fitness
Belt is slipping
Mar 29, 2010 | RTO Image 15.0R Treadmill Walking Belt
How to tighten belt...Vitamaster by Roadmaster
Mar 09, 2010 | Exercise & Fitness
Remove water pump
Disconnect battery earth lead. Do not turn crankshaft or camshaft whn timing beld removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of rotation (unless otherwise stated) Do not turn engine via camshaft or other sprockets. Observe all tightening torques. Remove engine, remve RH engine mounting. Remove auxiliary drive belts, water pump pulley, crankshaft pulley, timing belt upper cover, timing belt lower cover. Turn crankshaft clockwise to TDC on No. 1 cylinder, slacken tensioner bolts 5 & 6. Move tensioner away from belt and lightly tighten bolts. Remove timing belt. Remove water pump and replace with new one. Suggest to replace cambelt as well.
Installation
Ensure timing marks aligned3 & 4. Fit timing belt in anti-clockwise direction, standing at crankshaft sprocket. Ensure belt is taut between sprockets on non-tensioned side. Slacken tensioner bolt 5. slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner bolt 6. Tighten tensioner bolt 5. Turn crankshaft on turn clockwise. Ensure crankshaft sprocket timing marks aligned 4.
Slacken tensioner bolt 5. Slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner 6. Tighten torque: 20 - 26 Nm. Tighten tensioner bolt 5. tighten torque: 20 - 26 Nm. Apply thumb pressure to belt at middle. Approximately 5kg. Belt should deflect to 1/4 of tensioner bolt head width 7. Belt tention can also be set using burroghs (BT-33-73F) tension gauge 10 at middle. Turn crankshaft 90 ° anti clockwise. Check belt tension is 9.5 16,5kg (engine must be cold). Install components in reverse order of removal. Fit cranckshaft pully. Tighten crankshaft pully bolts 8. G4-J: Tightening torque: 12-15Nm.
G4-N/G4-k: Tightening torque: 10-12Nm
G4EA: Tighten crankshaft pully bolt 9. Tighten torque: 140-150Nm.
Nov 04, 2009 | Hyundai Excel Cars & Trucks
Belt is slipping on healthrider treadmill
Apr 30, 2009 | Icon Exercise & Fitness
Motor is running but belt isnt moving
Mar 31, 2009 | Proform 650 Crosstrainer Treadmill
Exercise & Fitness Logo
18 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
