Question about Navman GPS
6 pin usb cable - Navman GPS
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
My problem is, my wire of barcode symble scanner is deffective, i want repair it and change it to new usb, hwo to change usb from the end rj11?
A USB connector uses 4 pins.
It may have 5 pins in it, (Depends on the style of USB connector), but only 4 are used.
http://pinouts.ru/Slots/USB_pinout.shtml
The number 1 pin is used for 5 Volts. 5 volts is transferred from the computer through the USB cable on Pin 1.
The number 2 pin is used for Data transference.
The number 3 pin is also used for Data (Information) transference.
This is DC electricity so there is a Positive connection, and a Negative connection.
Pin 2 is the Negative connection.
Pin 3 is the Positive connection.
Pin 4 is used for Ground.
Suggest you match up the style of connector you have with the illustrations on the link.
Find Pin 1.
Look at your existing USB cable, and note what color wire goes to what pin.
Write it down.
Use the above to replace the USB cable.
For additional questions or clarification to what has been stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Symbol Computers & Internet
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
How do you connect to your computer
You can buy this cable or use the one provided by Brother
Belkin PRO USB 6' Cable USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft
Belkin Cable 4 pin USB type A (M) , 4 Pin USB type B (M)
Detail in this link
http://www.superwarehouse.com/Brother_MFC-3220C_5-in-1_Color_Multi-Function_Center/MFC3220C/p/332703
Apr 22, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
I need a camera cable (USB) for my casio EX-Z9 exilim. How can I find the right one?
You can get the correct lead from almost any large computer or photographic store, it does not have to be the official Casio item.
The lead needs to be a standard USB socket at one end (USB type A) and the other end is a micro USB (micro USB type B). This is by far the most common type for many cameras and phones now so shouldn't be expensive or difficult to find.
Alternatively, ditch the cable altogether and use an external card reader. Removing your memory card and putting it into an external reader to transfer images is usually much faster, especially if you also avoid using the clunky and non-essential software which most cameras are supplied with.
I hope that you've found my reply to be of use and ask in return only that you rate my answer.
Nov 05, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
USB
On your Mboard there are pins grouped together as such
Now below these pins there should be a message USB 4 or USB Front or something to that effect.
using your USB Cables starting from left to right on the top row of pins plug in this order RED - WHITE - GREEN - BLACK, you should be left over with the last spare pin on the far right. Plug the second USB Cable in the exact same order in the secon row
If your pins are such . . . . .
Then Just Plug the USB Cable The same way but going from right to left starting with the RED plug on the far Right hand side
let me know how you go
Regards
Jan 29, 2008 | Mercury P4VM800M7 Motherboard
15 pin to usb
Yes there are some converters that you can use to plug your joystick to USB:
For example:
http://video-games.search.ebay.com/_Video-Games_W0QQsacatZ1249QQsassZwwwtvpscom
http://cgi.ebay.co.uk/USB-to-15-Pin-Joystick-Gameport-Converter-Adaptor-Cable_W0QQitemZ300178219822QQihZ020QQcategoryZ74943QQcmdZViewItem
Dec 10, 2007 | InFocus VGA Cable - 15 pin male-male, 4...
GPS Logo
13 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
