Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
Yth 2146 stalls &runs rough - Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
1995 Neon Stalls or runs rough on occasion
You need to clean the throttlebody
Feb 23, 2016 | 1995 Plymouth Neon
2004 chevy silverado 5.3L V8 runs rough and stalls
Well, code 336 is for a problem with the crank sensor, and code 171 is for fuel system too lean bank one which is the side with cylinder one. Since you have checked fuel pressure and I will assume fuel volume is good, the crank sensor or circuit could be at fault.
Jul 09, 2013 | Cars & Trucks
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
My 2005 ford 500 stalls and runs rough on cold start only.
may be leaking or you need a new transmission or carb
Mar 17, 2013 | Cars & Trucks
1992 cavalier runs rough,it will run for awhile but then will stall,it runs rough when you shake the car so i changed the fuel filter and pump still runs rough the OBD code is 66 what does that mean??
code 66 is the a/c pressure switch. which will not make car run rough and stall unless its back feeding power. run engine with ac off and unhook connector to high pressure switch. the most common reason for running rough could be a bad sparkplug or sparkplug wire, check the wires and plugs also check dist cap and rotor for arcing. and last is how old is the o2 sensor, a bad o2 sensor can also cause this problem.
Oct 17, 2011 | 1992 Chevrolet Cavalier
Runs rough and wants to stall on acceleration also runs rough when ac is turned on
It sounds like you need a complete tune up and filter change on the car/truck. By doing this it should correct your problem. Hope this will help you.
May 20, 2010 | Cars & Trucks
2006 dodge 3500 deisel runs rough and no power codes are p2146,p0299,p0483,p0513.Wondering what the codes are meaning
code#2146 fuel injector group a supply voltage ckt (open) code# po299 turbo/supercharger (underboost) code# po483 control fan rationality check (malfunction) code# po513 immobilizer (incorrect)
Mar 28, 2010 | 2006 Dodge Ram 3500 Truck
Engine stalling
hi,you my check the distributor cap and rotor clean or replaced if necessary.
Feb 01, 2009 | 1992 Mercedes-Benz E-Class
I need emerson VCR codes for my 6 in one 15-2146
out of the manual: 0037, 0184, 0000, 0121, 0043, 0209, 0002, 0278, 1278, 0479, 1593, 1479
Jan 12, 2009 | Radio Shack 15-2146 Remote Control
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
32 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
