Question about Samsung DualView TL205 Digital Camera
Wont charge usb - Samsung DualView TL205 Digital Camera
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
Camcorder hrdpj10 wont charge via usb
Hello you can download the manual here:
http://esupport.sony.com/US/p/model-home.pl?mdl=HDRPJ10&template_id=1&region_id=1&tab=manuals#/manualsTab
The camera does not charge via usb.
You have to connect the power supply to charge up the camera:
Good luck
Dec 26, 2012 | Sony Handycam HDR-PJ10 Camcorder
My ipad wont charge , icon shows it's charging but it not ?
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
Oct 12, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Blackberry curve 8520 wont turn on, no red light wont charge or do nothing when the usb is inserted
maybe a bad cord. if it charges normal on the charger then it needs to be setup so it will charge thru the usb
Jul 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
My blackberry phone wont power up or charge
It probably wont power up because it wont charge. the USB port may be bad preventing it from charging. I assume you have tried both the wall charger and the computer connection and have not had any luck with either one. Its probably the USB port has stopped working. common problem if the USB cable had been yanked or severely stressed while plugged in to the phone
Feb 16, 2010 | RIM BlackBerry Curve 8310 Smartphone
Hp ipaq wont charge from usb cable. turns on for a few seconds nd loads but then turns off. it wont fully charge.
On the the IPAQ 6515 and others, there is a USB Power option that you must enable to 'slow' or 'fast' charge from USB connection.
Jan 13, 2010 | HP iPAQ HX4700 Pocket PC
Wont turn on
Your charger may be damaged, if the device is charged via USB, your USB port may be damaged / disabled, try an alternate USB port / computer, try an alternate charge of exact specifications.
Your battery may be damaged, the unit may be damaged. If your Zune is still under warranty, request an RMA from the manufacturer.
If it is NOT still under warrenty, please locate the nearest electronic componant repair shop, or remanufacturer
May 19, 2009 | Microsoft Zune120 Digital Media Player
Using USB in car as external power
the unit uses power EQUAL to what it is being charged with, when plugged into the USB.
you need to leave it on the DC (cigarette lighter) charger overnight to charge it fully, or use an AC plug for the Motorola Razor (min-USB) to charge it in the house
Feb 12, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Wont charge
hello, i think you are haveing the same problem i am having. i dont know for sure but i think the usb has to be a 2.0 usb to charge.
Jan 10, 2008 | RCA OPAL M4001 MP3 Player
Samsung DualView TL205 Digital Camera Logo
16 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
