Question about Air Tools & Compressors
Where can i buy nails for tooltec air nailer 9021
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
  • 1388 Answers
SOURCE: CRAFTSMAN NAILER
Generally, if your nailer is not leaking air, the orings are probably ok. Remove the head and check for stuck headvalve or stuck driver/piston. Make sure that you can press the headvalve into the head with your thumb and that it returns. If your driver/piston is down when you pull the head, remove the cylinder and check for damage to it or the bumper. Some cylinders have an oring or strip of rubber about med section which acts as a check valve causing the piston to return to top. Check for bent driver or broken tip causing driver to jamb. Use silicone lube to assemble. Enjoy
Posted on Dec 08, 2008
rowdy45176
  • 2176 Answers
SOURCE: air nailer won't nail
If youve never done anything to it could be a couple things. Have you kept it oiled (about 6-8 drops) before using and again at lunch if construction type work. Check the nails to make sure they move freely in the magazine Check the nail guage for proper size. and what I would do is fire it till it skips disconnect the air from tool and open the front door (for removing jams) and see the driver position. If it is partially down that would be the problem, check the driver for being bent. Lastly remove all nails and just tap the nose on a piece of wood and again check the driver position, if it moves or falls freely then the tool would have to have new rubber which might be a good idea anyway. Get back to me with the model number and I will research and see if they make an o ring kit.
Posted on Jan 21, 2009
  • 3 Answers
SOURCE: I purchased a new FN16250K-2 finish nailer today. I loaded it w/
get a senco
Posted on Mar 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Posted on Oct 06, 2009
I have propulse 2 inch Brad Nailer. Model 57265001. when i press switch just air blow out but no nail or nailing
1. Does it have any nails in it? A) add nails
2. Often when you get down to the last few nails it will quit working. A) add more nails, you may have to discard the remaining nail or three before adding more nails.
3. You may have reached the end of a group of nails and the last nail or 2 are jamed up in the end of the nailer. A) Need to open end of nailer and remove jamed nails. Don't forget to disconnect nailer from compressor first.
4. Other options are not enough air pressure, or the gun is damaged and needs repaired or replaced.
Good luck.
Aug 02, 2016 | Air Tools & Compressors
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Porter cable FR350 round head nailer type 2 fires when it is connected to air hose and won't fire afterward
Various nailers will fire on their own when connected to air if the orings have become hard or worn and internal trigger valve parts worn-out (mostly Dewalt and P/C). You could buy an oring kit or purchase trigger valve seperately. Replacing trigger valve and lubing the headvalve with white grease will most likely solve the problem. After repairing the gun, be sure to remove the nails from the mag after each use to prevent possible discharge of nail. Good luck
Oct 21, 2012 | Air Tools & Compressors
I have a Spotnails Framing Nailer MNS-5 and need a manual or a list of nail types i can use.
The nails for these guns are no longer produced by Spotnails. I am a Spotnails dealer and you can have them made by special order but the cost is not worth it. Buy a modern gun that uses something more common like the Paslode/Senco style 34 degree clipped head nails or a coil nailer. The MNS5 was a good tool but used an odd nail (I believe it is 15-17 degree without looking it up) and the tool has long been obsolete. It's too bad as I still have some parts and guns.
Jul 29, 2012 | Spotnails Mns Framing Nailer Oring Repair...
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Porta Nailer Air leak ( gasket ? ) compression chamber
More likely an O-ring. When they spring a leak, you buy a kit that contains all the gaskets and O-rings and replace them all. An easy job. Hope this helps.
Apr 07, 2010 | RTO Porta Nails Porta Nailer 403 Porta...
Stanley coil roofing nailer not sinking 3 1/4
That model may not be designed for that length nail. Check with your local supplier.
Mar 10, 2010 | Stanley Bostitch Coil Framing Nailer
The nailers piston that drives the nails is cracked onley drives nails half way in
im afraid that if the piston is cracked, then you have to replace it ( since you know that it is cracked then ill assume that you know how to remove and replace it) you can buy one at your local nail store or you can try toolpartsdirect.com,,, please rate this ,, tks
Dec 15, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
Air Tools & Compressors Logo
52 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
