Question about Air Tools & Compressors
Hydrovane 502 compressor oil leak - Air Tools & Compressors
Do you have the output specs for a Hydrovane 975 SQ model?
PDF]Hydrovane 5-7-8 Series Compressor - Compressed Air ...
www.ca-intl.com/files/products/hydrovane-5-7-8-series.pdf
Hydrovane's design and production excellence, combined with a strong .... ModelMotor Capacity Rotor Noise Oil Motor. HP SCFM@ Speed Level - dB(A) CapacityVoltage. 100 PSIC .... 128 PUAS 67.00 28.25 39.5 975 1.00 20.25 x 22.25 n/a.
Nov 26, 2015 | Air Tools & Compressors
CompAir Hydrovane 830 running but no air in tank
It must have a leak somewhere or be rotating in the wrong direction? Is it wired up correctly.Hyrovane compressors usually run quickly is the motor spinning well.
Jun 08, 2015 | Air Tools & Compressors
How can I stop water coming through the air line on Hydrovane 139 CWD
you will always get a small amount of moisture coming through your air hose, but sometimes it can be minimized by draining the water accumulation in the tank by bleeding it out from the bottom plug. make sure that there is no pressure in tank before you remove the plug to drain water.
Sep 15, 2014 | Cars & Trucks
V09a1aa4ak oil capacity
There is no need to add oil to an ac compressor unless you have had a massive leak. new compressors come with the right amount of oil. The compressor oil circulates with the gas and by the time the gas pressure drops from a leak then the amount of oil leaked out is just a few drops. Excessive oil in the system stops the TX valve from working and causes problems . If still in doubt then talk to an accredited ac specialist
Aug 01, 2014 | 2010 Mazda 2 1.25i
Hydrovane HV11 user manual
control pennel lights keeping on flashing
Jan 25, 2014 | Manual Units Sphygmomanometer Pressure...
HDC 2HP 5 Gal Pancake Air Compressor - replaced pressure switch - now takes long time to pump tire - motor runs long time - slow recovery - actually overheated and melted off the plastic part on muffler....
Barb:
Your compressor takes standard 30 weight compressor oil or 30 weight motor oil... you need to put in the correct amount. The slow recovery is due to a leak somewhere. after adding the proper amount of oil, run the compressor and use a soapy solution to check for leaks. Check especially the tube that runs from the compressor head to the tank, and also check the air connection at the pressure switch. When you find the leak, you can disconnect the connection and use Teflon tape on the male end connector.
Aug 15, 2013 | Air Tools & Compressors
How to wire 3 phase compressor
threett phase takes another hot from main so you will be adding another hot on to youer line to make mo tor work .problm is most services arent three phase that are residental their only two legs of 120 that combined make 240 n so on
Jun 20, 2013 | Air Tools & Compressors
I have an compair hv11 hydrovane compressor. everything works fine until the unit is switched off, then a mist pours out of the air intake side until the air is fully discharged. any ideas,
Hi, my name is John. Welcome to FixYa. You need to bleed the water from tank. Loosen the valve at the bottom of tank until all water is out. I bleed mine daily. Thanks for choosing FixYa....John
Nov 26, 2010 | Air Tools & Compressors
Oil leak on aircon compressor and does not blow cold air. have refilled gas twice and blows cold for one day and warm the next day.also compressor does not engage
if oil is leaking on the compressor you may have a valve cover gasket leak have that replaced and that will stop your leak problem.your compressor has a leak in it also thtas why its not engaging. you should have it dye tested in order to find out what really is leaking in the system.
Dec 11, 2009 | Toyota Camry Cars & Trucks
R.S.U probe fault on a hydrovane 845 .compressor has been off for 3 months .Just fitted new main motor power on and have this fault
RSU stands for Rotor Stator Unit.
If you just fitted a new motor DO check the rotation direction is what it is supposed to be.
Nov 19, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
83 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
