Question about Coby Televison & Video
Coby 26" tft lcd tv BLACK SCREEN when green power lights is on after unplugged a few days displayed a very faint Coby image and went to dark screen again even with green light still lite.
SOURCE: PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Posted on Dec 18, 2007
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
  • 1779 Answers
SOURCE: COBY TV TF-TV1514 15'' TFT LCD TV
Go into your menu and navigate to find Closed Caption then turn it off. That should do it!!!! Read your manual also, it's possible you might have POP picture in which it displays multiple channels when you change it. That feature should also be in your manual.
Posted on Feb 18, 2009
ginko
  • 19396 Answers
SOURCE: Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Jun 16, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
www.cpsc.gov/.../Thirteen-Re...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
https://www.ifixit.com/.../Coby_DVD-209_Ultra_Compact_DVD_P...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics
www.consumeraffairs.com > Electronics > Televisions
Dec 21, 2015 | Coby TFDVD2284 22 LCD TV
Coby tv will not come on
Died and went to monitor heaven. U can always check out the power supply. But other than that you may need to go shopping.
Jul 28, 2017 | Coby 20" Flat Screen TFT LCD TV Monitor
Hi i have a coby 26" LCD TV model no TFTV 2617. How Can I get all my high definition channels. I all ready auto program it & it does not work
i have a coby 26 , I know sorry about that, but if any can help I appreciate it . turned set on today and green lite only no pic/sound/snow did have a horizontal red line for a few days prior to today.
Jul 15, 2011 | Coby TF-TV2617 26 in. LCD TV
My 26" LCD tv has black screen When I was watching it screen went black unplug ova nite still Same thing barely see movement IN back Ground up really close so but it have sound But black screen can...
Good day!
LCD screens have very thin fluorescent light tubes. if you can barely make out an image its most likely that the Power inverter board that powers the lights is damaged.
Aug 24, 2010 | Televison & Video
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
No image on the screen
missmai and guest, the ballast supplying the CCFL tube may not be working. PCB board is in the lid (Cover) where the LCD screen is mounted. Careful opening it...the membrane (loom) attaching LCD and PCB when stretch too much could render a blank or white faulty display.
If the store where you bought this player do not give service support and parts, you might just have to toss it and forget about it. There is nowhere to get it because the same model you have now is carried by another two (2) brand names plus Coby. Sorry...its the fact...i will let you know if there is a fourth brand.
Good Luck.
Jan 27, 2007 | Coby TF-DVD7107 Portable DVD Player
Televison & Video Logo
24 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
