Question about Toshiba Satellite A55-S106 Notebook
Toshiba satellite a200-ah3 won't accept over 2GB of RAM
5 Suggested Answers
  • 73 Answers
SOURCE: I'm formatting my laptap to windows xp, i need a support software
get the installer disk from windows that is the only legal way to do it (hint)
Posted on Mar 24, 2009
  • 10406 Answers
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Posted on May 27, 2009
tbreeze47
  • 3083 Answers
SOURCE: how do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
Posted on Feb 25, 2010
wings_it
  • 141 Answers
SOURCE: Toshiba Satellite A200-AH3 will not accept more
The max RAM you can install onto it is 2GB. If you are thinking overclocking it (using RAM above 667.0 MHz), then it's a bad idea the cooling system was designed to cool it at stock speeds, not at overclocked speeds.
If you still want to try and burn it, then make sure you have matching sticks of RAM, then enter the memory configuration menu in the BIOS and disable the default memory profile. Adjust your memory multiplier by selecting a preset overclock option or by typing in the RAM clock speed. Use increments, one or two at a time, that match consumer-grade products (DDR3 RAM is typically sold in increments of 800-1066-1333-1600-1867-2133); save the changes; and exit the BIOS.
Good luck
Posted on Oct 18, 2013
Satellite A200-AH3 will not accept more than 2 GB of RAM
Hi Sir, you may encounter that because your motherboard doesn't support larger memory. If you want to upgrade your PC, replace your motherboard.
Hope it will clear your mind.
Thank you.
Oct 17, 2013 | Computers & Internet
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
I have Toshiba satellite a200 laptop when i turn on my laptop it has continues beep sound and it doesn't log in
check or change your ram first then also make sure that your keyboard is not having a stuck button.
regards
Apr 02, 2011 | Toshiba SatteliteĀ® Pro A200 PC Desktop
Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
Jun 15, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba laptop wont start up
change the ram (Random Access Memory) on your laptop your ram is not working
Regards
manish
Mar 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
Mar 24, 2009 | Toshiba Satellite A200-S18X01G Notebook
EXTENDING EXIST 2Gb RAM to 4Gb
hai ,frist u go to
start--my computer(right click it)---manage---disk management---
see your new hard disk & right click and shirnk volume
Jul 13, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
